TPI throttle body differences
Old Mar 17, 2002 | 07:21 PM
Iroc n roll's Avatar
I've heard there are differences between the 85-87 Throttle bodies and the 88-92 throttle bodies. What's the difference and are they still interchangeable?
Old Mar 17, 2002 | 07:24 PM
topdown's Avatar
I've worked on 305 and 350 TPI's from 86 to 92 and I have yet to see a difference!
Old Mar 17, 2002 | 09:53 PM
DKING's Avatar
The 85-88 throttle bodies had a IAC control passage, which also can be seen on a 85-88 plenum. While the 89-92 plenums are missing this IAC passage. An early throttle body cannot be used on a later plenum, but a later throttle body can be used on a early plenum. I got this out of my TPI Swapper's guide. It's a good book that can help you find what you are looking for.
Old Mar 17, 2002 | 09:55 PM
Are there any differences in the linkage for the TV cable and throttle cable?
Old Mar 17, 2002 | 10:07 PM
DKING's Avatar
I don't think so. I know that Lokar makes a throttle cable that will fit all years, it just needs to be cut to fit. You can find them in Jegs or Summit for $31.99.
Old Mar 19, 2002 | 07:41 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Just the throttle cable is different.
On the 85-87 the throttle cable fits over a pin on the lever and is held in place with a snap ring.
88's and later the throttle cable has a pin on the end of it that fits into a recess in the throttle lever.
this is the way it is on my two cars
Old Mar 19, 2002 | 07:57 PM
So then the throttle cable from an 85-87 will NOT fit a 88+ TB...correct?
Old Mar 19, 2002 | 08:10 PM
No, they are not interchangeable, but check with the dealer, I believe the cable is still available, or maybe you could find a used one.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
