Where to get a Speed Denisty engine harness?
Old Mar 19, 2002 | 07:46 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i need some ideas as to where to get a speed denisty engine harness.
does GM still offer a harness for a 91-92 F-body?
what internet sites are there that sell them?
Old Mar 19, 2002 | 08:30 AM
Beefy89's Avatar
I see them on e-bay now and then.
Old Mar 19, 2002 | 10:22 AM
91banditt2's Avatar
Engine: 5.7 HSR
i'd like to find a brand new GM harness.
Old Mar 19, 2002 | 01:17 PM
Beefy89's Avatar
I believe Summit sell Painless harnesses for around $300.
Old Mar 20, 2002 | 07:26 AM
91banditt2's Avatar
Engine: 5.7 HSR
come on there has to be some peoplein here that know of places to get a brand new GM wiring harness?
Old Mar 20, 2002 | 07:37 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I got my new GM speed density harness from Lambert Buick, it was cheaper than GM parts direct.
Old Mar 20, 2002 | 08:37 AM
NevermorE's Avatar
If you want to buy direct from GM your gonna pay a lot! Probably in upwards of $500 or more. You could most likely order them from any Chevy dealer.
As for painless they probably should be called painintheass. They work great in the engine, but don't expect to have things like power windows or dash light. Apparently it's good for building up a hotrod, not for a conversion.
As for ebay, GOOD LUCK! I've been looking for months now, i've seen a few MAF harnesses, but no SD harnesses. I've got a few leads, but it looks like i may have to have my tbi converted to tpi. Heres a guy that'll do it for around $150
http://chevythunder.com/speed_density_harness.htm
Old Mar 20, 2002 | 10:11 AM
a73camaro's Avatar
Why not get one from a wrecking yard, and pick one from a V6. If I understand it correctly, the only difference between a V6 - 730 and a V8 - 730 is two injectors with the wiring harness.
Double check this. This is hearsay from this board.
Old Mar 20, 2002 | 02:11 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I believe all V-6 Camaros were MAF not MAP (speed density). So the harnesses won't be a direct swap.
Old Mar 20, 2002 | 03:40 PM
a73camaro's Avatar
Are all V-6's (Buick 3.8 engine) MAF driven?
Old Mar 20, 2002 | 07:39 PM
Drew's Avatar
Wrong. 90-92 3.1L V6's use MAP.
From looking at the wiring diagrams in my shop manual, the circuits are the same and since both are batch fire, etc it should be relatively simple to modify a 3.1 harness to work with an L98, but some plugs have to be changed, plugs need to be added, some wires need to be shortened or lengthened, etc..
Old Mar 21, 2002 | 01:46 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
V6's are MAF and MAP the same years the V8's are MAF and MAP. The 90-92 3.1L uses the same computer as the V8's as well, the 7730 speed density. But the chip is different.
Old Mar 21, 2002 | 03:21 AM
Jza's Avatar
Jza
I'm currently converting a MAF harness to an SD harness, and it's actually surprisingly simple.
You basically buy the extra yellow plug that the 7730 uses and repin the wiring to use all three connectors in their proper positions for the 730. You add the wiring for the new stuff (most of which you can shuck from your old harness) Then you can (if you want to be thorough) remove the wiring that the 730 no longer needs (MAF sensor, MAF burn-off relay, MAF power relay, EST wiring, etc.)
Fun fun fun:rockon:
Old Mar 21, 2002 | 10:15 AM
Beefy89's Avatar
Heres one. http://cgi.ebay.com/ebaymotors/ws/eB...tem=1814023907
Old Mar 21, 2002 | 11:30 AM
Drew's Avatar
The guy selling that harness is a good seller too... I bought some parts from him a while back... they were grade A and were packaged great and shipped quickly.
Old Mar 21, 2002 | 01:12 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Transmission: TCI 700R4
Axle/Gears: 12 bolt with 3:73's
give jims performance a try.
www.jimsperformance.com
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
