Miniram pics
Old Apr 4, 2002 | 08:50 PM
GTABANDIT's Avatar
Miniram pics
Does any one have pics of the miniram installed or can someone tell me or show me what is needed to hook up the fuel rails to the fuel lines on the car. it is a 89 ga thanks!!!
Old Apr 5, 2002 | 07:35 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Fuel Lines ...
MiniRam Pics...
Tim
Old Apr 5, 2002 | 09:20 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Hey TRAXION, I noticed that the miniram has an opening between the runners under the plenum in the back. Does that continue all the way to the front of the intake? Kind of like an Edelbrock air gap intake?
Old Apr 5, 2002 | 12:39 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Trax - Do you have the dimensions you used to block off your A/C holes in the firewall? It looks really clean and my s/s plate just isn't cutting it for me.
Old Apr 5, 2002 | 12:54 PM
NEOMASTERZ28's Avatar
Car: 85 z28
THIS IS A MINRAM its like an LT1 but has room for the distubitor where can u buy 1 at and u have to get a new computer or what ? just trow it on any 350
Old Apr 5, 2002 | 02:19 PM
TRAXION's Avatar
The opening goes all the way through exactly like an 'air gap intake'.
Tim
Old Apr 5, 2002 | 02:20 PM
TRAXION's Avatar
Sorry, I don't. I gave a buddy my entire AC box and asked him to trace it on some 1/16" aluminum plate and then cut it out. That's what he did. I then painted it black because it was too darn shiny Eventually I will have it painted the same color as the engine bay.
Tim
Old Apr 5, 2002 | 02:23 PM
TRAXION's Avatar
Did you fail english? ;-) j/k
Available from TPIS for around $900. You need to buy at least their base fuel rail kit which means another $250. You don't need a new computer but a custom computer chip is somewhat necessary ... especially for the pre '89 cars.
Tim
Old Apr 5, 2002 | 02:24 PM
GTABANDIT's Avatar
Traxion thank you very much for the reply ! Have you ever seen the install with the tpis hard lines and install kit they have some rubber fuel lin that is not braided dont think i want to use it thanks again.
Old Apr 5, 2002 | 02:39 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
That's a good idea. I can trace something off the A/C components. I have two stainless steel plates there right now, just something to cover the firewall so I can pass tech at the track.
If you want to match the paint pretty close, I bought a can of Duplicolor 1200 degree paint in "Red" and you can't even tell there's a plate there. I also have a 1990 Bright Red Iroc, so our paint should be about the same. =)
Old Apr 5, 2002 | 05:05 PM
bobs89irocz's Avatar
Actually brand new the miniram with rails cost $1200 plus you have to get a tb. Call TPIS at 952 448 6021 its worth every penny
Old Apr 5, 2002 | 09:06 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
are you saying I can't use my 58 mm BBK/Edelbrock throttle body with this?
Old Apr 6, 2002 | 01:56 PM
TRAXION's Avatar
I actually bought the hard-line install kit that was suppose to be made for the F-Body. IMHO it was a joke. The lines were kinked pretty darn bad from the bends they had to put in them. Furthermore, there was not enough room for me to connect it all up because the IAC/TPS was in the way. I still have them laying around in a junk pile somewhere.
Tim
Old Apr 6, 2002 | 08:36 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Trax,
I like those valve covers, are they Moroso? j/k
How much taller are they than stock centerbolts? I need an extra half inch clearance or so, and they look nice.
gixxer92
Apr 12, 2022 12:09 AM
86IROC112
Oct 9, 2015 10:38 PM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
