Do all '82s come with 200c trannies?
Old Apr 27, 2002 | 04:37 PM
ThirdGen Stoner's Avatar
Same as title
(doing swap to th350 in a '86)
Old Apr 27, 2002 | 06:00 PM
SOMEONE has GOT to know!!
Old Apr 27, 2002 | 07:40 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Either a 200c or a 4 speed standard Saginaw. If your looking for a TH350 swap for your 86 I suggest you find a full sized truck with a TH375 and use it. This 375 has the same sectional tailshaft as a TH700R4 so you can swap them over and mount the tq arm brace, it also uses the same detnet cable as the 200c&700R.
Old Apr 27, 2002 | 08:47 PM
I really appreciate the info, but im sticking with the 350...
THANKS
Old Apr 28, 2002 | 02:18 AM
ronterry's Avatar
Car: '94 Corvette
I don't think the TH-700 saw life till the 83 models.
BTW: I have a 200c setting in my garage (Can't give it away), from my 200c - 350 swap...the swap is a piece of cake...
Ron
Old Apr 28, 2002 | 03:37 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Not sure, but this might come in handy:
1982
Saginaw 4 Speed Manual transmission (Z-Bar)
Borg Warner T10 4 Speed Manual Transmission (Z-Bar)
TH200C 3 Speed Automatic transmission
1983
Saginaw 4 Speed Manual transmission (Z-Bar, 4 Cylinder Only)
Borg Warner T10 4 Speed Manual Transmission (Z-Bar, 4 Cylinder Only)
TH700R4 4 Speed Auto Overdrive Trans
Borg Warner T5 5 Speed Manual (Non world class, Z-Bar)
1984
Saginaw 4 Speed Manual transmission (Hydraulic Clutch, 4 Cylinder Only)
Borg Warner T10 4 Speed Manual Transmission (Hydraulic Clutch, 4 Cylinder Only)
Borg Warner T5 5 Speed Manual (Non World Class, Hydraulic Clutch)
1985-1988
1989-1992
Borg Warner T5 5 Speed Manual (World Class, Hydraulic Clutch)
This information is accurate to the best of my knowledge. My transmission is out and lets just say I have been doing a little research.
Old Apr 28, 2002 | 12:06 PM
LOL, thanks for all that info man! I am going from a 700r4 to th350 so all I need is the xmember and drive shaft off of a 200c. And I found one ('82 camaro) in a junk yard and was wondering if it was a 200c. But I guess it has got to be one since its an auto. The only thing is its a V6 and was wondering if the xmember and ds would be the same as a V8......
Old Apr 28, 2002 | 03:05 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
The DS and cross member is the same, I used my crossmember and ds out of my 4cyl bird, and both sre holding together just fine.
Spud
Old Apr 28, 2002 | 03:40 PM
Thanks spud
Old Apr 28, 2002 | 05:56 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have a Q regardign all this, i have an 82 trans am 305 car and has th350 in it right now, originally auto trans car, so was th200 at one time,
now when the previous owner put the 350 in wouldnt he have to have a tailshaft for it that has the holes in ot to mount up the torque arm bar back to the rear axle ?! what am i gonna find when i crawl under car ? anyone guess ?
am i gonna want ot look under there ? tranyn and engine hahve to come out soon anyways, i dont think tranny is any good, may need rebuilt dunno yet for sure,
and engine is a 350 4 bolt truck that bottom end siezed up somehow. i pulled the top end off the engine today, it had 82 305 heads on it, 14062201 heads..
thanks
Old Apr 28, 2002 | 08:23 PM
Im not sure, but he might have put the B&M kit on it....
Old Apr 29, 2002 | 12:19 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Fast68, you will most likely see this adapter on the tailhousing of the TH350. It allows you to bolt the stock torque arm to the TH350 without a custom tailshaft.
http://store.summitracing.com/partdetail.asp?part=12452
its part number BMM-30299 from Summit.
Old Apr 29, 2002 | 08:59 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting, i doubt that the previous owner spent all that much $$ on it to convert it, probably iwl find a jimmy rig under it.,,
am still afraid to look under, i may do it later today though. found out engine is an 82 truck 350 though, TBL suffix code
thanks!
Old Apr 29, 2002 | 12:15 PM
indy82tx's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
I have an 82 LU5 that originally came with a 200. It was converted to a T350 before I bought it. The previous owner had welded the torque arm attachments to the T350 tail housing. They did a pretty good job and it doesn't look like too big of a deal to do.
The kickdown cable was from a 70's T350 truck.
I recently converted to a T5. I had to get a different crossmember, shorter drive shaft, and located new holes in the frame for the crossmember.
Ken
82 Z28, LU5 still alive
Old Apr 29, 2002 | 03:30 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
found out my 82 ta actually does stil habe the th200 in it and its rebuilt one, damn... so is all correct inderneath.
you sayinh 5 speed is longer than short th350 ?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
