Governor woes....
Old Apr 28, 2002 | 09:06 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Governor woes....
Here's the deal.
I swapped in a used fairbanks tranny with my vigilante. It was set-up to shift WOT at ~6k. Part throttle was a little long 2-3 & 3-4 but nothing extreme.
Anyhow, 6k was way too much for a stock 305, so i swapped in the governor from my old tranny that shifted ~5k @ WOT, and was actually short shifting part throittle due to being from a 2.73 car with 3.23s.
In the fairbans tranny things are different. It's doing 1-2 anywhere from 54-5800 inconsistently, and 2-3 @ 47-4800. Thats not too bad, but i would like to get that 1-2 down some. The problem though is part throttle. This thing is trying to wind first way out all the time (3-3500 minimum), even barely touching the gas. This is kinda annoying. 2-3 is late as well, and 3-4 is fine.
Any ideas on a givernor that might be more reasonable at part throttle and give me 5k WOT shifts. Am i doomed to TnT with the B&M kit?
Old Apr 29, 2002 | 10:27 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Governor woes....
Originally posted by Ed Maher
Here's the deal.
Try setting your tv cable out 1 click at a time. That'll make it shift sooner, part throttle. I'm running mine out 3 clicks right now, to get the part throttle shifts I wanted. I'm shifting into 2nd at about 7mph, but I'm also running a 410 gear.
Old May 3, 2002 | 10:24 PM
Ed Maher's Avatar
Car: 04 GTO
Do you know what a bad idea it is to run with the TV cable loose. Thats so wrong i'm not even going to comment further on it...
Old May 5, 2002 | 08:03 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Just buy the B&M governor kit and start playing with the springs and weights. It took me three tries to get it right with my 87 GTA.
HikoriYami
Sep 21, 2015 07:11 PM
crazynights
Aug 21, 2015 06:53 AM
88transam5.0
May 3, 2002 10:07 AM
EDDIETA_ZZ3
Jul 5, 2001 05:59 AM
92Z
Feb 16, 2001 11:03 PM
