T5 swap checklist
Old May 19, 2002 | 07:07 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
T5 swap checklist
folks, help me make sure i have everything i need to swap in the T5.......
T5 (duh)
bellhousing
flywheel
clutch disc
pressure plate
throwout bearing
master cylinder
slave cylinder
shifter
clutch/brake pedals
torque arm mount
clutch fork
Dexron III ATF
i cant find a anywhere that carries a correct VSS since i have a 2.73 rear end, so i'm just gonna wait until i either swap in a T56 or change the rear to 4.10's
Old May 19, 2002 | 06:52 PM
Blue91''s Avatar
VSS
A T-5 never came in a car with 2.73, the lowest ratio it was matched with was 3.08 in a V8 car , not sure about V6 cars but they are usually higher ratios anyway.I did the swap in my 91 RS V8 and the speed sensor I used was P#1045687. if you are not using a manual prom you will also need to jump out 2 wires at your park nuetral switch (where you auto shifter was) for the ECM or you will get a VSS code.The 2 wires are Black w/White stripe and Orange w/ Black stripe. The blue and green are you reverse lights, and the 2 heavy guage wires Brown and purple (I think, cant remember the colors for sure) are you neutral safety switch wires. I found neutral safety wires (same color) under the drivers side knee kick panel by the fuse box as well, I guess the factory harness has it in both places so which ever trans the car was ordered with , the N.S. wires were in either location.Hope this helps.Also , you diddnt list pilot bearing, and I would use all new flywheel bolts etc..
Old May 19, 2002 | 07:49 PM
ummmmmmmm who ever said anything about putting this into a v6
this is going into my Z28 that is an LG4 and non-CC.....................
thanx for the part #
Old May 19, 2002 | 07:51 PM
ummmmm mine is a wire driven speedo not electronic
would that part still be the same
i dont think so............
Old May 19, 2002 | 08:16 PM
Blue91''s Avatar
That Part # Is for electronic VSS used for TBI and TPI cars w/manual and 3.08 gear with electronic VSS 90-92. I assumed you were going to need that one.My fault. Just trying to help you out.
Old May 19, 2002 | 10:10 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Re: T5 swap checklist
T5 (duh)
bellhousing
flywheel
clutch disc
pressure plate
throwout bearing
master cylinder
slave cylinder
shifter
clutch/brake pedals
torque arm mount
clutch fork
Dexron III ATF
How much have you spent so far....if ya dont mine me asking.
Old May 25, 2002 | 05:02 AM
thanx for trying
Old May 25, 2002 | 05:08 AM
Re: Re: T5 swap checklist
haha the swap is costing me more than the car
1987 LG4 Z28 $600
T5 tranny $150 (that includes shipping)
bellhousing, clutch fork, bolts, master cylinder, slave cylinder, torque arm mount all for $50
brand new GM pressure plate $100
clutch disc $100
resurfaced flywheel $125
pilot bearing $3
throw out bearing $33 (didnt pick it up yet from work)
ALL labor by myself $free
$561 grand total
:rockon:
Old May 25, 2002 | 05:09 AM
oh yeah, i am trading my auto pedal straight up for a manual pedal setup
so thats free
and the shifter came with the tranny
and the manual console cover cost me $5 at the swap meet
Old May 25, 2002 | 07:56 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
i dont now if this helps but the part no# on my speed sensor is 10456087. an i have a 92 rs with an lo3 an t-5
Old May 25, 2002 | 12:12 PM
thanx alot man
but i think you got better gears
(i have 2.73's)
and from 82-89 camaro speedo were cable operated
90-on are electronic
firebirds are different
thanx though
Old May 25, 2002 | 10:56 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
where did u get a working t=5 for $150? i plan on blowin mine up with my new engine so i need a back up
Old May 26, 2002 | 05:43 AM
on this website of course!!!!!!!
its actually a V6 transmission so i had to go hunting for the correct clutch disc
yes, i know its weaker, but i need to get the Z28 on the road so i have a backup car
the guys was selling the 2.8 engine and transmission for $150 but he didnt want to ship them
so i offered him $100 for the tranny plus shipping if he did ship it, so he agreed and i got a working T5 for only $150
if you want this tranny to work, you'll need to get a centerforce clutch disc for a 1991 chevy lumina
its 9 3/4 inches, so its a little smaller, but should hold the power
:rockon:
Old May 26, 2002 | 10:23 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Luminas came with stick?
Do you have a part number for that clutch disc?
And also, what type of pressure plate are you running?
I have a 9 5/8" inch clutch in my 84, I'm also running a v6 t-5
Old May 26, 2002 | 09:08 PM
does it slip at all robert??
i will go to centerforce's website right now and get you the number
Old May 26, 2002 | 09:10 PM
heres the part number:
CF360119
Old May 26, 2002 | 09:11 PM
oh yeah, i went with a stock GM pressure plate since i work for a GM dealer and get a nice discount
and i got a resurfaced flywheel
Old May 27, 2002 | 09:01 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
If you got on the clutch while the car was running, it would slip.
More or less a safety device of sorts to try and prevent running a bigger clutch which I think would exert too much pressure on the input shaft of the tranny, and break it.
And actually, I believe the clutch disc I am running is from an S-10.
Old May 27, 2002 | 09:05 PM
hmmmm that sucks
i hope the 9and 3/4 will be big enough to handle the power
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
