how can i calculate how off my spedo is?
Old Jun 17, 2002 | 12:14 PM
fattie92's Avatar
iv got 275/60/r15's in the back, connected to a 3.23 gear on my 84 TA. i was wondering how i can calculate how far off my spedo is.
Old Jun 17, 2002 | 01:24 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
This might help:
http://www.chevytalk.com/tech/index.html
Click on Transmissions there & there is an article with links on how to calculate.
Old Jun 17, 2002 | 06:23 PM
fattie92's Avatar
thanks
Old Jun 17, 2002 | 07:44 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Also, www.700r4.com/ has a calculator. If you use what tire size is supposed to be on the rear of your car and the new size it will tell you how many teeth difference on the driven gear. 1 tooth equals 1.8 to 2 mph difference.
Old Jun 17, 2002 | 09:07 PM
fattie92's Avatar
what was the normal tire size on a 84 ta???????
Old Jun 17, 2002 | 09:08 PM
alex13507's Avatar
or you could use the more precise method... do about 75 by a cop... in a 45... then subtract 10 from what he says!!!
sorry... had to say it...
Old Jun 17, 2002 | 09:30 PM
fattie92's Avatar
i must be a retard, cuase i cant figure this out. there isnt a way to figure out how many MPH your off?
Old Jun 18, 2002 | 06:17 AM
Ricktpi's Avatar
Here is another one:
http://www.fbody.com/calc.htm
Look at the last one on the page.
Old Jun 18, 2002 | 12:26 PM
fattie92's Avatar
who can put 275/60/r15 in inches?
Old Jun 18, 2002 | 01:18 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I posted it last night, guess it diddent go through. Your supposed to have 215 65 r15 tires on stock 15in rims. Your new tires require 15 tooth drive gear and 35 tooth driven gear, or an 18 tooth drive and 42 tooth driven to be correct. The correct count for the stock 215 65 15's is an 18 tooth drive and 45 tooth driven. Your about 8MPH slow with your new tires.
Old Jun 18, 2002 | 05:02 PM
fattie92's Avatar
8mph slow all the time? or at a certian speed? i found out that 215's are 26inches in dia.. but what are 275s?
Old Jun 19, 2002 | 01:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Your 8 MPH slow in every gear. The calculator @ the web site I gave you doesent need the metric size so 26 or what ever in doesent matter. What does matter is the fact you need a 42 tooth drive gear to correct the speedometer reading, since you should have the offset speedo housing, assuming your car came stock with those gears you just need an $8 part to get the correct speed.
Old Jun 19, 2002 | 04:22 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
go on the highway and use the mile markers. Count one mile and see what your odometer saids.
Old Jun 19, 2002 | 04:38 PM
fattie92's Avatar
is it a pain to change the gear?
Old Jun 19, 2002 | 05:02 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
it can be if you've never done it before, but theres a first for everything. Ask a near-by thirdgen.org member to give you a hand.
Old Jun 19, 2002 | 06:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
NO! Its very simple. All you need is a 10mm wrench, pliers, a jack and a jackstand. The housing that the speedometer cable goes into is what you need to remove and it only takes about 10 min to do the job. You need to make sure the speedometer housing is the offset one I mentioned. The standard housing is not offset and the 42 tooth driven gear will not fit but if your car came stock with the 3.23's it "SHOULD BE" an offset housing, GTG.
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
fasteddi
Sep 2, 2015 10:29 AM
