T-56 Swap
Old Aug 10, 2002 | 03:47 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
T-56 Swamp
I have an 82 Trans Am with the stock 200C tranny and a 305. Heres what I need so far.
Parts Needed From where
T-56 with bellhousing speedautomotive.com
4th gen Driveshaft speedautomotive.com
Energy Suspension Polyurethane Transmission Mount Summit/Jegs
Roller pilot bearing Summit/Jegs
Rear main seal Summit/Jegs
Spohn Crossmember Spohn
Spohn Torque Arm Spohn
Vehicle speed sensor Dealer
Electronic Speedometer carparts.com
Third gen pedal assembly Junkyard
T56 master/slave cylinder assembly speedautomotive.com
I have one question. One person said I will have to use a third gen pedal assembly. Anyone know if I can use the pedals from a 4th gen?
Old Aug 10, 2002 | 08:57 PM
Metalifann's Avatar
You also for got the clutch, pressure plate, throwout bearing, plus the special pre-85 flywheel.
Old Aug 10, 2002 | 08:58 PM
JR305's Avatar
I used the fourth gen pedals on my 92 rs. The fourth gen pedals come with the clutch, brake, and gas connected. I just cut the gas pedal off and it bolted right in.
Old Aug 10, 2002 | 10:16 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Well, when I said tranny and bellhousing I meant everything in the bellhousing. Sorry
What is the difference between a pre 85 flywheel and others?
Is their a difference between the 82 and later third gen pedals?
Thanks for your help!
Old Aug 10, 2002 | 10:45 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I'm 90% sure the 82-92 manual pedals are all the same.
Old Aug 11, 2002 | 11:04 PM
blk87z28's Avatar
Metalifan, where do I find this special flywheel? I have a '78ish small block and a '94 t-56. any help, links, dealers, etc. will be greatly appreciated.
aaron
Old Aug 11, 2002 | 11:24 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
I think centerforce makes the flywheel you need.
Old Aug 12, 2002 | 12:22 AM
Metalifann's Avatar
Fidanza makes an aluminium flywheel for it. I need to get one for my swap. I'll be calling them within a few days and will get my price on one. I'll let you know how much I can get you one for.
Old Aug 12, 2002 | 12:24 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Another guy told me he used the flywheel from the T-56 in his swamp. He said be sure to grap it from the donor car because the cheapest aftermarket one was like $400.
Old Aug 12, 2002 | 03:13 PM
SSaudio's Avatar
I bought mine online when I did that same swap. Try www.car-part.com if they don't have it, then I don't think they make it! lmao, it's a nationwide data base of junk yards. I bought my 95 t-56 there too as well as my 95 camaro leather seats! Try it out, you'll love it!
Old Aug 12, 2002 | 03:16 PM
Metalifann's Avatar
I believe that the bolt patterns on the 1 piece rear main and the 2 piece rear main cranks are different.
Old Aug 12, 2002 | 04:45 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I plan to get a used T-56 with bellhousing(everything inside it) shifter, master cylinder, tranny mounts, crossmember,and I'm not sure if it comes with the pedals for 1,550. If its cheaper anywhere else, I'll try it.
Old Aug 12, 2002 | 07:57 PM
JR305's Avatar
Is that with a custom crossmember? I got everything I needed minus the custom crossmember for 1500.
Old Aug 12, 2002 | 10:54 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The crossmember is not modifyed. I'll see if I can order it without one for less $$$. I also won't need the mounts.
Old Aug 13, 2002 | 12:02 AM
blk87z28's Avatar
I found the fidanza at scoggin dickey, a little outa my price range at this time. I will check out centerforce but i havn't found one there yet. The factory never put the pullstyle (LT1) clutch on a two-peice rear main block to the best of my knowledge. the wheel on the LT1 motors has the wrong hub for my motor. What about drilling the old 153 tooth from the t-5?
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
cRoe4
Aug 7, 2015 08:46 PM
