is it bad to....
Old Aug 31, 2002 | 04:51 PM
cobrakiller1989's Avatar
is it bad to....
keep it floored in OD with a 700r4? i just had the transgo reprogramming kit installed in my trans and i can now keep the car floored in OD and i thought i remembered hearing something about it being bad to do that.
thanks
Old Aug 31, 2002 | 05:42 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I dont think the transgo kit had anything to do with that....maybe a misadjusted tv cable. And no, flooring it in OD wont hurt a thing. But you may want to look into things a bit. You should not be able to do that if your tranny is working correctly. Sorry..
Old Aug 31, 2002 | 06:00 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Its supposed to shift down to 3rd if you use over 70% throttle I think.
Old Aug 31, 2002 | 07:43 PM
yeah, but i had the kit put in with the full manual option on it. its just like i have a manual valve body now...
Old Aug 31, 2002 | 08:04 PM
Engine: 406
well thats a horse of a different color...I have no idea how it is supposed to act in od with that option......the only thing I know is bad on od is a heavy load re; towing and large inclines..
Old Sep 1, 2002 | 03:49 AM
transfixleo's Avatar
I don't recommend the full manual option for the street. Since you have it now YOU have to know to downshift the Tranny at WOT.
Old Sep 1, 2002 | 10:20 AM
So say i downshift the tranny at WOT and run 3rd gear out to 5500rpm can i keep it floored when i shift it into Overdrive or will this be harmful on my trans, i just thought i remembered hearing soemone say that its not good for the trans.
Old Sep 2, 2002 | 03:09 AM
Since that is @ the WOT shift point you will be OK. In fact, NOT shifting and running it above that RPM can do harm too.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
