LS1 driveshaft swap
Old Sep 6, 2002 | 11:20 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
LS1 driveshaft swap
I have a vibration in my car above 55-60 and I'm pretty sure it's caused by a bent driveshaft. I've heard of people using LS1 driveshafts in 3rd gens. I was wondering if this is a direct swap or if it requires cutting/fabrication, ect. I guess I'm going to have to replace my driveshaft and I want to make sure the LS1 piece will work before I buy it. Thanks!!
Old Sep 8, 2002 | 10:05 AM
Anybody?
Old Sep 8, 2002 | 11:07 AM
mechanicalmehem's Avatar
direct replacement
Old Sep 9, 2002 | 03:55 PM
Ah, yes, finally an answer! Thanks!! I can go lay down some more cash now
Old Sep 10, 2002 | 12:19 PM
brian89transam's Avatar
Are the the LS1s much better? I thought I read somewhere that they were bigger than the 3rd gen L98s. What's a good price for an LS1 driveshaft?
Old Sep 10, 2002 | 01:14 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
From what I hear its thicker yet hollow or something. Its lighter and also better balanced.
My question is...is ALL LS1 driveshafts like this? or is it only certian models? Cause imma go searching probably on thursday and I dont wanna end up buying a driveshaft tahts exactly the same as the on I have now O_o
Old Sep 10, 2002 | 08:42 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
3.23 and 3.42 geared LS1 cars came with aluminum DS from the factory...
2.73 equiped LS1 cars have a steel DS from the factory
Old Sep 10, 2002 | 09:03 PM
they all seem to go for around 100$. also, a quick easy(from factory) a car with Z-rated tires will have the alum DS, easiest way IMO if you are unsure, take a magnet with you.
Old Sep 10, 2002 | 10:44 PM
MikeS's Avatar
revlimit,
not that it really affects the conversation, but our driveshafts are hollow as well.
Old Sep 11, 2002 | 12:26 AM
Does anyone know the weight difference between our steel ones and the aluminum LS1s?
Old Sep 11, 2002 | 08:07 PM
a lot probably 50-100 lbs.
Old Sep 11, 2002 | 09:38 PM
89Irocz23's Avatar
wtf? 50-100 IBS? they dont even weigh that much...my stock one might of weighed like 40 if that. The ls1 ds I have is maybe 15-20 or so.
Old Sep 12, 2002 | 09:21 AM
grovier's Avatar
the ls1 ds is that from a manual trany or a auto tranny. or does it matter.
Old Sep 12, 2002 | 01:21 PM
89Irocz23's Avatar
It doesnt matter both bolt right up
Old Sep 12, 2002 | 02:09 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
What about the u-joints or the yokes? Do I need the ones from the LS1 or what?
Old Sep 12, 2002 | 03:18 PM
89Irocz23's Avatar
The driveshaft I bought had all the u joints and yoke already on it...so everything bolts right on..im not sure if you can use your old yoke and u joints or not. Id say if your buying a used shft id replace the u joints with good ones. There is where I bought my driveshaft from. It was about $240 or so with shipping, but everything is bran new. http://www.eecis.udel.edu/~davis/z28...up/misc/ls1ds/
Old Sep 12, 2002 | 04:39 PM
u r sofa king we tah did's Avatar
dont get the LS1 shaft if you plan on using drag slicks, it will rip it all up. its about as thick as a 3 inch piece of exaust pipe. the steel one is a bit thicker. the alum is better balanced though.
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
