is it possible...4wheel Drive...
Old Sep 10, 2002 | 06:49 AM
JayB's Avatar
Is it possible to achieve 4 wheel drive by implementing the 4wd selector unit off of something like a chevy blazer into your thirdgen? Its something ive thought about doing, but i have not the clue if its even possible. What would i have to change in the car itself...would i have to add, a new axles or anything...Give me some advice...
Old Sep 10, 2002 | 11:17 AM
Momar's Avatar
hehehehehehe
Old Sep 10, 2002 | 11:19 AM
Momar's Avatar
Oh, sorry, your being serios right. Anyway, you would have to have like the whole setup out of a truck with everything needed to power teh front wheels. You would have to put a lift on your car. It wouldnt be worth it.
Ben
Old Sep 10, 2002 | 11:24 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Just swap the Camaro body with a S10 4WD pickup frame & drive train. Alotta work fitting, welding & such. Is it worth it ? Well.....
Old Sep 10, 2002 | 03:37 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
it sounds more like you want all wheel drive not 4wd there is a difference.S10's mostly have part time transfer cases(front shaft directly connected to rear with out clutches). if you could get a transfer case and front diff under an fbody you'd want one from a newer cherokee or blazer or something w/full time 4wd
Old Sep 11, 2002 | 11:01 PM
mikesstkiroc's Avatar
If you want a all wheel drive then go look at an import or something. Subaru sell some nice quick cars so does Mitsu. F-body's are rear wheel drive cars not AWD cars or trucks.
Old Sep 12, 2002 | 12:14 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
We already have enough of a ******* image why add to it.
Old Sep 12, 2002 | 06:47 AM
86budgetSC's Avatar
I have a 91 GMC sonoma that is 4wd.I totalled it in july.I have toyed with the idea of putting my camaro body on it.(I would never really do it)But I don't think it would be worth it.The wheel base is different.All kinds of things.Plus I think it is retarded anyway.
Old Sep 12, 2002 | 07:40 PM
Jester's Avatar
LOL no..it can't be done. Even if you had the skill the do all the fabrication that would be nessecary....you could never get it to fit. But I suppose you could put the selector switch into your thirdgen and pretend.
Webmouth247
Dec 7, 2010 11:42 PM
firebirdman
Sep 5, 2010 12:22 PM
bungo78
Southern California Area
Apr 14, 2010 02:34 PM
AlwaysSidewayz
Carburetors
Nov 17, 2009 07:41 PM
