Why do my rear wheels spin the same way??
Old Oct 22, 2002 | 08:25 PM
Steve89GTA's Avatar
Stupid question but, I raised the rear on my GTA the other day and I noticed that if I spin the drive wheel one way...the passenger one (and vice versa) spins the same way. I always though due to the differential that the 'other' wheel should spin the 'other' way.
hmm, Is my rear end shot? Oh, it's a 9bolt 3.45 rear.
Old Oct 22, 2002 | 08:42 PM
EvilCartman's Avatar
Car: '82 Z28
Sounds like it's working perfectly normal for a posi rear.
Old Oct 22, 2002 | 09:56 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Old Oct 22, 2002 | 10:02 PM
iroc22's Avatar
It will only differentiate around corners.
Old Oct 22, 2002 | 10:20 PM
JPrevost's Avatar
Car: 91 Red Sled
It's definatly NOT a torsen posi unit
You've got a clutch posi, when you change diff fluid make sure you add the additive!!! Unless you don't like your posi.
Do a burnout and check for 2 lines of rubber.
Old Oct 23, 2002 | 05:39 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It's a 9 bolt so it's a cone style posi unit (technically still a clutch, but to most people a clutch is disk style). To check if the posi is working correctly, it should take ~ 40lbft to rotate the tire (when the other is fixed). Anything less and the posi is getting worn out.
Miles
Diff Solutions
www.9bolt.com
Old Oct 27, 2002 | 12:31 PM
MdFormula350's Avatar
yeah sounds like you have a posi rear end..
Old Oct 27, 2002 | 03:36 PM
Birdman7389's Avatar
Nope that rear end is shot!!! Lemme take it off your hands real cheap-like!
Old Oct 27, 2002 | 06:36 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yeah Steve...ahem...that rear is gonna go on you anytime.....ahem...I've got this 10 bolt here that spins great in both directions...ahem...trade???
Ed, with envy of an '89 3.45
Old Oct 27, 2002 | 06:38 PM
ebmiller88's Avatar
Hey Miles, any way to check if a posi is good when the diff is out of the car?
Thanks..Ed
Old Oct 27, 2002 | 09:39 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Same way, just lock one of the axles and put a torque wrench on the other.
If it's just the carrier, then insert a pair of axles.
Miles
Old Oct 30, 2002 | 07:37 PM
Keith27's Avatar
Should both wheels move?
Im about to take the rearend out of my 88 parts car(9-bolt disc brake 3.27) and put it in my 91 Formula.
With the car off the ground I can spin the left wheel easily, but the right wheel is tougher. But if Im spinning one wheel, shouldnt the other wheel spin the same direction?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
