4L60 E '95 only?
Old Oct 22, 2002 | 11:19 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
4L60 E '95 only?
i am installing a '95 LT1 in my '92. i have a harness that is for that car.(1995) it sais it will run 4L60E & 4L80E. I want to upgrade, and i want to use a 4L60E. the wrecking yards here keep telling me that it was one year only, and so they want to rape me for the tranny. is this true? is there a way around it? what are these trannys worth? please help. this project has overwhelmed me, (the whole swap), and i just want it to come out right.
Old Oct 23, 2002 | 01:32 AM
ronterry's Avatar
Car: '94 Corvette
You can always get a 4L60E from a '94-'96 Vette...
Ron
Old Oct 23, 2002 | 02:58 PM
Marc 85Z28's Avatar
Both 94 and 95 got the 4L60E. 96-02 got it also. There might be a difference in the 96+ due to OBDII, but I'm not sure. They should all be the same. You can use a Vette tranny, but you will need to change the tailshaft. The Vette has no provisions for a torque arm.
Old Oct 23, 2002 | 03:25 PM
ronterry's Avatar
Car: '94 Corvette
With the torque arm, you could always go with a Spohn, or Jegs. Both do NOT need special deals on the tailshaft.
Ron
Old Oct 25, 2002 | 05:35 AM
transfixleo's Avatar
It is one year only. You do need the correct PCM to operate it.
Old Oct 27, 2002 | 09:18 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What?? The 4L60E was used from 94 to the present. Whats so special about 95's??
Old Oct 27, 2002 | 11:05 AM
gearhead86's Avatar
95-97 4L60E should work. Like transfixleo said you need the correct PCM to get the correct interface between engine and transmission. 1995 was pre OBD2 but it still is a pretty smart PCM for the age. One thing that I have learned noseing around salvage yards over the years is that just because the salvage yards interchange list says it wont fit and work isnt necessarily so. You have to do a little research on you own sometimes.
Old Oct 27, 2002 | 02:05 PM
sinner's Avatar
i know. thats where u guys come in.
Old Oct 31, 2002 | 06:39 AM
In '95 there was both a PWM TCC control AND PWM 3-2. Only year with that combo.
Old Oct 31, 2002 | 07:00 PM
sinner's Avatar
so what do i have to change to make another year work with my '95 computor and harness?
Old Nov 1, 2002 | 07:26 PM
gearhead86's Avatar
All 4L60Es from 93 to present run PWM for the 3-2 downshift solenoid. They started adding the PWM for the TCC in 1994 on some models and made it across the board in 1995. They made changes to the valve body in 1996 for the 3-2 downshift(they simplified it less parts in the valve body). But that shouldnt pose a problem from the computer standpoint the trannies are dumb they only do what the PCM tells it to do. Any 4L60E from 95 up that is a 2 wheel drive and came behind the old style small block should work all you would have to do is bolt on the correct tailshaft .(Although they wont have the better shifting pieces like the F and Y body trannies) The later trannies look a little different the the older ones but fitment should be the same. Anybody else have any input jump on in!
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Linson
Nov 12, 2015 08:09 PM
C409
Sep 1, 2015 03:42 PM
Ryan_Alswede
Sep 15, 2001 09:28 AM
90RSconvert
Sep 25, 2000 10:07 AM
