9 bolt open to posi
Old Nov 7, 2002 | 06:14 PM
biff85ta's Avatar
Car: 04 Vette
9 bolt open to posi
I have a nine bolt drum brake open diff and have located a 3.42 posi ten bolt that needs a pinion bearing I could probably pick up cheap like under $100 should I buy the ten bolt or just upgrade to a new carrier and the 3.45`s in my 9 bolt it has 3.08 gears now.
Old Nov 7, 2002 | 07:55 PM
Steve86TA's Avatar
Car: To many to list
Are you sure you have a 9 bolt with drums and 3.08 gears?I have never heard of a drum 9 bolt or a 3.08 gear in it.10 bolts had drums3.08's though.
Old Nov 7, 2002 | 09:22 PM
MdFormula350's Avatar
you should go with the 10 bolt and fix that bearing and use that, they are cheaper for to buy parts for and are close to the strength of a 9 bolt..
since it already had the 3.42 gear with posi your all set.. 100 bucks is good verses the price to fix the 9 bolt..
Old Nov 7, 2002 | 11:23 PM
4mula's Avatar
9 bolts ONLY came with 3.27:1 gears, posi and disc brakes and have a ring gear of 7.75" instead of 7.50" for the 10 bolt. 10 bolts are fine in a stock car but I took half the teeth off of the gears twice and broke an axle in 3 pieces before I installed a 12 bolt! no more problems
Old Nov 8, 2002 | 05:09 AM
Steve86TA's Avatar
9 bolts came with 2.77,3.27.3.45,and very rarely 3.70
Old Nov 8, 2002 | 08:38 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ed
AND 3.08s...ask Miles at diffsolutions.com and my factory service manual.
No lie, they're out there.
Ed
Old Nov 8, 2002 | 12:43 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
A 7.5/7.625 10 bolt is nowhere near the strength of a 9 bolt!!!
All the 9 bolt info you need is at www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
Old Nov 8, 2002 | 02:20 PM
biff85ta's Avatar
Car: 04 Vette
Steve86ta I too believed that all 9-bolts were posi disc units until I crawled under my car for the first time and saw the borg-warner cast into the bottom of the housing and realized there was a rubber plug in the cover and until I went to 9bolt .com I believed that I had a posi someone had burnt the cones in. Thanks to everone on their input keep it coming still haven`t made up my mind would like to here from people who may have had both and see what they think.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
