Will my 700R4 explode now?
Old Nov 21, 2002 | 08:19 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
stock 700R4. 500 horsepower motor.
NO slicks, No T-brake.
Will the stock 700R4 blow up (as in KABOOOOM!!!)
or will it just start slipping when its time to replace it?
Im worried about shattering it and parts flying everywhere. will this happen? or will it simply not work anymore...
Old Nov 22, 2002 | 12:26 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I would say its going to start slipping............as mine does....
Old Nov 22, 2002 | 09:01 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
But yes a transmission can blow up behind a 500hp engine, as in physically go kapbom and send pieces of case and gearset through the floorboard. Not common, but can happen, even with a built transmission behind big HP engines.
Thats why the sanctioning bodies have tranny blanket / shield requiremenets.
Old Nov 22, 2002 | 01:01 PM
MdFormula350's Avatar
hopefully just start slipping and not go kaboom!!
Old Nov 22, 2002 | 03:52 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
hmm so it could blow up, but hopefully not.
Hmm..
is it likelly to blow up? Even without slicks and T-brake?
With just normal 255/60/R15 tires holding it back?
Consider 500 Ft.Lbs of torque @ 1500 RPM-4500 RPM.
Yeah, massive tire slippage, but, will this affect the life of the tranny in a Negative(KABOOM!) way? or will it just wear it out?
My dillema is should I spend the $2300 on the rebuild/converter NOW or wait till its TIME to rebuild? I could use that money elsewhere if i knew the tranny wouldnt go KABOOM!
Old Nov 22, 2002 | 07:21 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
Coming from my own exp...
My 350 cranking about 380-400 horse spanked my tranny.
my 85 iroc sits restless with 3rd n OD gears ripped. Just my two cents, i'm putting a turbo400 in. Sucky gas mileage but better performance and durability.
Old Nov 23, 2002 | 12:44 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>my 85 iroc sits restless with 3rd n OD gears ripped</b>
boom? any permanant damage to the tranny? anything else get boomed?
Old Nov 23, 2002 | 03:19 AM
EvilCartman's Avatar
Car: '82 Z28
My torque converter went POP on my 200c in April... sounded like a shotgun going off. Sprayed everything down with transmission fluid leaving about a 3 foot wide pattern on the road. That was behind just a 305
Old Nov 23, 2002 | 05:12 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
nothing else (praise the lord) but I haven't looked.
I'm thinking me de-tent cable shattered so my tranny (doubtfully) is still good. But the way a 700r4 gears are, it don't sound like a cable problem since I do have 1st n 2nd. one of the big differences between r4's n turbos is that instead of a cable (r4) to control the tranny shifts delays n actions, the turbos have vacuum lines which I think are better. Are like I said, turbos are more durable and if you want any horsepower n performance, go with a turbo!
Old Nov 26, 2002 | 09:15 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
yeah ive got a Th350 now in my other car. thing is, i need overdrive. you know, daily driver and all that.
sigh* well i dont want to explode anything, sooo.... eh.
i guess ill drop my 700R4 off to be "built" by this reputable shop over here... say... on that note...
what converter? I want a 9.5" 2400 stall lockup. who makes the best?
Old Nov 26, 2002 | 11:34 AM
Ed Maher's Avatar
Car: 04 GTO
Even if you spend every penny you can find on a rebuild a tranny can still explode behind a 500hp engine. Even the best race built trannies can and do physically explode. Like i said, thats why the sanctioning bodies have tranny blankets in the rules for fast cars. Because when a lot of power makes aluminum and steel explode, it can cause injury or death.
Basically, not much you can do to prevent it, **** happens, you know. The question is, are you doing everything to protect yourself for the kind of worst case damage a fast car can cause. On thing to blow up your tranny and wreck, thats racing. It's another thing if a piece of shrapnel gives you a high speed lobotomy or takes off your leg.
Old Nov 27, 2002 | 05:00 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Just don't beat on the trans or it will die
Right Ed?
Old Nov 29, 2002 | 08:22 AM
Bob86ZZ4's Avatar
Do the conversion to a th400 with a Gear Vendors overdrive behind that. I did mine this way last winter and I love it. I now have 6 forward gears to choose from. It is perfect for autocrossing and road racing. It will cost you, but so what. Don't waste money trying to build a strong 700r4. Just my opinion here, I'm sure others will differ.
Old Nov 29, 2002 | 03:49 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>Do the conversion to a th400 with a Gear Vendors overdrive behind that. I did mine this way last winter and I love it</b>
Wayyyy more money than I have available. I mean this is a $600 car, I dont need to invest more in a tranny than the cars worth. heh, or maybe I do. thats why its a $600 car.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
