ECM/TCC/T-5 to auto/Is TCC needed?
Old Dec 2, 2002 | 08:50 AM
88irock's Avatar
My car was a T5 stick factory, but it was converted to a 700R4. I don't think the ECM or wiring harness were changed, but unsure as I bought the car the way it is. It runs pretty good, and the transmission seems to shift good. I was under the car and saw a connector with the wires cut, and after researching the boards, I think this is the wiring for TCC.
Do I need this hooked up, or will the car be OK without it? Is a 5spd ECM and an auto ECM the same (same wiring outputs, etc)? Can I find an auto harness and throw it in and cure the problem, or would I need a new PROM in my ECM/or swap my ECM for an auto ECM? I also saw a few other connectors under the car that aren't hooked up, but I don't know what they do, should I try to ID them and get them hooked up too?
Thanks for any help/advice, also, what could I pick up a used T5 for, as I still have a lot of the 5spd accesssories, like the shifter, cluch pedal assy, fluid reservoir under the hood, etc.
Thanks again, and sorry for long post.
Old Dec 2, 2002 | 11:19 AM
88irock's Avatar
Anybody?
Old Dec 2, 2002 | 11:55 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
I think that the worst thing you could see here is worse gas mileage. Without it hooked up it will result in higher RPMs at highway speeds. As for the difference in ECMs... I dunno. The chip however is most certainly different.
Old Dec 2, 2002 | 12:22 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
ECM is the same, the prom is different...usually the only difference is the prom is programmed for the TCC on an auto.
Old Dec 2, 2002 | 02:16 PM
88irock's Avatar
Thanks guys, any other people feel free to put in an opinion.
Thanks again, and by the way, can I wire the TCC to work automatically as in an auto car if I wire it directly to the ECM I have, or would I need an automatic PROM for it to work?
Old Dec 2, 2002 | 02:18 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
you will need to have a PROM from an auto that is programmed to signal the TCC, the stock PROM in the manual was not programmed to do it.
Old Dec 3, 2002 | 12:15 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
dude i got the wire digram for you and I'll post it after I get out work about 7pm pst
good luck
Old Dec 3, 2002 | 06:12 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yes you need a TCC lock-up, don't change your mind and skip it. Without it the transmission will end up burning up the fluid and thus the tranny.
Old Dec 4, 2002 | 03:49 AM
88irock's Avatar
Thanks all, AYMAN, I'll be watching for the diagram...
Old Dec 4, 2002 | 07:10 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
well yesterday my scaner gave me a hard time but I'll post it
if does not work I'll fax it or mail it
Old Dec 4, 2002 | 11:29 AM
88irock's Avatar
Thanks, I'll check my mail
Old Dec 5, 2002 | 01:09 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
here it is
Old Dec 5, 2002 | 01:24 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
oops it said invalid ext
i sent an email with wire diagram
Old Dec 5, 2002 | 07:06 AM
88irock's Avatar
Tried to open, but it didn't work...
Thanks for trying though.
Old Dec 5, 2002 | 10:02 AM
Nordbert's Avatar
Check out this wiring diagram. I think the switch should say
"normally open", though.
Old Dec 5, 2002 | 10:09 AM
Nordbert's Avatar
What the.....?!!! Note to self: PYHO!!
This site should have been on my last post! http://www.technicalevolution.com/700wire.gif
Old Dec 5, 2002 | 11:06 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I'll try another way
Old Dec 5, 2002 | 11:30 PM
88TAJeff's Avatar
Car: 88 T/A
Why don't you just wire a relay to lock up the TCC when the tranny hits 4th? this way, you don't have the annoying TCC lock/unlock in 3rd
jklein337
Sep 19, 2018 06:23 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
