Corvette servo Install Help
Old Jan 26, 2003 | 11:47 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I am trying to get the 2nd Apply Piston off. Does the piston come off separately or does the pin come out with it. I get the piston to a certain point on the pin and then it stops. This leads me to believe I have to remove the piston and the pin but to do that I would have to drop the transmission because it hits the floor pan.
Old Jan 26, 2003 | 05:08 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
the whole pin comes out....have someone pry the tranny to the side while you try to remove it.....you may have to remove the X member...go here...http://www.impalassforum.com/tech/dr...nsgo_servo.htm
Old Jan 26, 2003 | 05:11 PM
Engine: 406
and here...........http://www.sethirdgen.org/servo.htm
Old Jan 26, 2003 | 05:13 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When I install them while still in the car, I found that if you unbolt the crossmember, and pry on the tranny to the drivers side, you will usually get enough clearance to remove the assembly.
Old Jan 26, 2003 | 11:48 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Thanks for the responses guys. I got everything apart and back together except for the case. I can't get it to go in far enough to get the clamp on. I can get the bottom of the case in but the top isn't going in quite far enough. I am pushing on the cover with a crowbar. Is there a better way or did I put something together wrong(which I don't think I did)?
Old Jan 27, 2003 | 02:23 AM
Engine: 406
a little vasoline on the o=rings helps to keep them in place....you may be pinching one...everything has to be very clean...
Old Jan 27, 2003 | 12:58 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Thanks for the reply's Riley. I finally got the cover on. I just had to put a little more umph into it. It is on and working like a champ.
Old Jan 28, 2003 | 05:11 AM
Engine: 406
Glad to hear it.... ...I wasn't so lucky on my first attempt...
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
