Trans will not shift into drive or reverse....
Old Jan 30, 2003 | 07:01 AM
Cam28_boy's Avatar
I just got my 6.6L tuned port started and running and know the transmission will not shift into drive or reverse. The engine starts in park and neutral like it should. Is there a possiblity that the overfilled trans fluid could have caused this problem? The only thing I remember doing to the trans is adding a new tci converter (2400-2800)...I left the transmission in while doing the engine swap. The shifter cable seems to be intact. What else could cause this problem.
Old Jan 30, 2003 | 07:17 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
are the tranny and motor COMPLETLY together? You may not have got your tc all the way on...you put it on the shaft then turn it until it goes on further....ask me how I know this...
Old Jan 31, 2003 | 04:45 AM
Cam28_boy's Avatar
Can this happen even though I have the engine and trans bolted together? I also have the flywheel and the torque converter bolted together...I thought.
Old Jan 31, 2003 | 05:19 AM
Engine: 406
when it happened to me.....the tranny case was away from the engine about 1/8 " at the top...had to really look to see it....the converter only sits about 1/4 to 1/2 " away from the tranny case ( bellhousing)....
Old Jan 31, 2003 | 05:22 AM
Cam28_boy's Avatar
Thanks alot...i'm going to check that as soon as I get home.
Old Jan 31, 2003 | 10:00 PM
Engine: 406
Keep me posted!
Old Feb 2, 2003 | 04:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It sounds to me like you didnt get the new converter seated all the way before bolting the engine up to the tranny. If this is the case, then thats VERY bad news for you. I have seen a few lucky people, but the majority of people who don't get the converter seated all the way crush the pump rotor.
Old Feb 2, 2003 | 07:17 PM
Engine: 406
Thats how I know!!!
Old Feb 4, 2003 | 05:14 AM
Cam28_boy's Avatar
I'm in the process of taking the torque converter off along with the trans. I hope that that the front pump isn't damaged or the torque converter. If so i'll be swapping in a built up th350. Thanks for the input GM Tech and Riley.
Old Feb 4, 2003 | 05:09 PM
Engine: 406
Good Luck!!
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
dhonda200
Aug 11, 2015 11:50 PM
