T-5 Swap- how big is the shifter hole i have to cut?
Old Mar 3, 2003 | 09:03 AM
91 Camaro Z28's Avatar
hey people, i'm getting down to the wire and i'm not sure how big of a hole i'm going to need to cut for the shifter. i'm sure i could just half-@ss it but I want it to look good and be functional. Is there a template or anything, or does anyone know the exact sizes? thanks- also, if you have any advice and no-no's for the swap, let me know. All help is greatly appreciated
Old Mar 3, 2003 | 09:24 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
When you take out the console you will see a flat spot on the tranny hump that is about 6 in wide by 8 in long. Cut that out staying about a 1/2 in from the edge. Install the tranny and check the clearance, then trim if nessesary.
Old Mar 3, 2003 | 07:11 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
As long as you can access the bolts holding the shifter to the trans, you should be good.
Pete
Old Mar 3, 2003 | 08:04 PM
what do ya'll recommend to cut the hole with?
Old Mar 3, 2003 | 09:56 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
If you have access to a plasma cutter, I say that would be the thing to use. It keeps the heat in a very concentrated so the risk of fire is very low (keep a fire extinguisher handy just in case!) It makes for very quick work. I used one, cut from insde of the car. But my hole for the shifter looks all horrid and crapitable. My next choice would be a sawzall. Easy to use, usually very easy to get a hold of. It doesn't make any sparks or get things very hot, but it gets metal shavings everywhere. Those two are your best bets, I'd say.
Old Mar 3, 2003 | 10:12 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
What about a air cutoff tool? I have one that seems to cut through sheet metal pretty good. Think it would work well?
Old Mar 3, 2003 | 10:58 PM
Car: 1991 Camaro RS
Are you talking about an airsaw, or the kind with a carbon cutting wheel? I personally thing a carbon cutting wheel throws too many sparks, and throws them too far. It'd almost be like a bunch of little cigarette burns in your interior. not cool.
Old Mar 4, 2003 | 01:35 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
nibbler
-Schultzy
Old Mar 4, 2003 | 05:20 AM
whats a nibbler
Old Mar 4, 2003 | 12:41 PM
Scott C's Avatar
Like tin snips, but with much more power...
Old Mar 4, 2003 | 02:50 PM
Car: 1989 GTA
whats a nibbler
It is actually a pneumatic tool that takes little bites out of sheet metal. You can drill a pilot hole and then just guide it around to cut out your hole.
-Schultzy
Old Mar 4, 2003 | 08:17 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i used a drill to make a hole at each corner then a tin snips to cut it out, sure it was a little tuff but not bad,
based on steel roofing experiance i'm gonna guess the floor pan in that area is about 26ga sheet metal
Old Mar 6, 2003 | 07:36 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
I used tin snips, took about 3min. and no sparks.
Old Mar 6, 2003 | 08:01 PM
i took my console out and didnt really notice any kind of place on the console that would indicate where the hole is supposed to go-- any suggestions??
Old Mar 6, 2003 | 09:58 PM
Car: 1991 Camaro RS
I put the tranny in place, raised it up to the floor pan and made marks in the road grime on the bottom of my car. That's how I positioned my pilot holes. You may want to be more specific and measure for you holes insted of freehanding like I did.
Jeremys87
Jul 14, 2022 09:08 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
Cacike
Aug 27, 2015 05:10 PM
LittleFranks
Aug 20, 2015 03:55 PM
mustangman65_79
Aug 13, 2015 07:36 AM
