200 4R problem
Old Mar 15, 2003 | 03:33 PM
82Z28NAZ
Guest
Posts: n/a
200 4R problem
at WOT high RPMs the tranny needs to shift but "searches" for a gear. Coming to a complete stop it won't downshift and the engine lugs.
Any Ideas?
Old Mar 16, 2003 | 05:56 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You need to correctly adjust the T.V. cable.
Old Mar 16, 2003 | 08:59 PM
82Z28NAZ
Guest
Posts: n/a
Tried the following...
push cable all the way in and ratchet out with gas pedal
push cable all the way in and ratchet out with the TB linkage
held throttle all the way open while pushing D button and pushing plastic sleave back
got any more ideas?
Old Mar 16, 2003 | 09:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 200 4R problem
Torque converter clutch solenoid.
Matthew
Old Mar 16, 2003 | 10:40 PM
82Z28NAZ
Guest
Posts: n/a
a local builder did mention something about the solenoid
also the tech said that it wasn't locking up
Old Mar 16, 2003 | 11:04 PM
jmd's Avatar
jmd
Unplug the 4 wire connector. Drive it for a week like that (200-4Rs do not burn up w/ out lockup as 700s do). You'll know whether it (TCC sol.) is your problem or not.
Do the 4th gear pressure switch, TCC solenoid, fluid and filter same time.
My 87 has my 86's original tranny in it. Trans. has like 171k on it now. I did the sol. some time ago.
Matthew
Old Mar 18, 2003 | 01:00 PM
82Z28NAZ
Guest
Posts: n/a
thanks a lot jmd... it was a quick fix!!!
gta892000
Aug 11, 2019 11:16 AM
ironbmt
Sep 27, 2015 06:00 AM
Bill 88TA
Oct 18, 2001 04:46 PM
Demon Z28
Pacific Northwest Region
44
Jun 5, 2001 12:48 AM
irocbob89
Apr 22, 2001 05:03 AM
