T56
Car: 91 Z28
Engine: LB9
Transmission: WC T5
T56
I know this has prob been asked before but I have to questions in particular about the t56, 1st question: is the clutch fork in the same place as a t5? #2: will it bolt to the t5 bellhousing, or do you need to get a new bellhousing for it to work? I know it has to be a 93-97 lt1 t56 for it to work, and I know that you have to get a diff. crossmember...is there anything else that I need to know? what about the driveshaft? can you use the stock driveshaft from a t5 with a t56? I know its a pita to answer these questions again, but I dont have time to do a search and wanna know what I need to accumulate before swapping a t56. Thanks
Car: '89 GTA
Engine: 427 BBC
Transmission: TH-350
you will need a new bellhousing as the T5 is at a angle and will not bolt to the T56, i got my cross member from SPD . I used my stock driveshaft from my A4.
A T56 is the same lenght as 700R4
Hope your swap goes as smothly as mine did
Re: T56
Car: '89 GTA
Engine: 427 BBC
not sure as if the clutch fork's are in the same place. But i remembered that you will need the master and slave cylinder for the clutch. I'm almost sure that the clutch fork piviots differently from a T5. maybe someone else could confirm that.
Car: `86 SS / `87 SS
Re: T56
The clutch forks are different and pivot in the opposite direction of each other.
The only T56 that bolts to a T5 bellhousing is the aftermarket T56 which comes with an adapter plate up front with a bearing retainer built in(?).. the 4th gen f-body and viper T56s do not bolt to a T5 bellhousing.
The complete production 4th gen LT1 T56 from bellhousing to tail is the same overall length as the 3rd gen T5.
You need to accumulate a bit more knowledge before jumping in. I have my hydraulic throwout bearing, 1995 T56 & bell, and lotsa other parts and am not quite ready to put mine in. But the T5 is pulled
Car: '89 GTA
Engine: 427 BBC
thanks jmd, i hate to give inacurate or incomplete info.
fast86, just do your research, i found everything i needed on the TGO board. Do you have the transmission crossmember sorted out yet?
bigjay89gta
Oct 15, 2015 08:04 AM
