1 Simple Question
Old May 7, 2003 | 12:17 PM
Strunthopht's Avatar
1 Simple Question
What is the best way of getting 100% of my WOT!?
Apparently the valve GM makes is only 75% and the one from B&M is 85%
Do I need the whole TV Plunger and cable?
If I'm wrong, lemme know
Thx..
Old May 7, 2003 | 03:26 PM
ANYBODY??
You guys tellin me that with all your infinite wisdom of a thirdgen.. you can't give me an answer??
That's not right..
Old May 7, 2003 | 03:53 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
b&m kickdown valve
I'm assuming you are referring to the b&m throttle valve sleeve... Yes, it does allow you to run in overdrive at wide open throttle at speeds over 70mph (if I remember correctly). As far as what you need to replace, it is the aluminum sleeve that the tv plunger goes into.. There is one roll pin retaining this sleeve in the valve body.. Just take the trans pan off, and its right there. Easily serviced in the vehicle...
Old May 7, 2003 | 03:54 PM
thirdgen88's Avatar
Car: 1995 Corvette
passing gear
one more thing, you can still manually shift it into third for easy passing power...
Old May 7, 2003 | 09:40 PM
I've heard of different types of kits..
some let me go 75% WOT and not downshift, some let me do 85%
I want the FULL 100%
so you're saying that replacing those parts will get me FULL 100%? and not only 75% or 80% compared to stock 50% ?
thx
Old May 7, 2003 | 09:45 PM
Basically, I just want to know EXACTLY what part(s) I need to get NO DOWNSHIFT whatsoever
Not 75% WOT 4-3 Downshift, not 85%, NO downshift at all
100% WOT.. Regardless of the price..
Old May 7, 2003 | 11:34 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
manual tranny
Old May 8, 2003 | 01:22 PM
ALMOST, but no..
I was more looking for some type of shift kit or the parts I need to make it 100%..
Old May 9, 2003 | 07:46 AM
thirdgen88's Avatar
Car: 1995 Corvette
I thought that I already told you this... I used to have the b&m kickdown kit, and it would not shift down into 3rd at highway speeds (or above)...
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
