B&M brackets, whats tranny mount bracket for ?
Old Jun 5, 2003 | 09:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok the B&M brackets arrived for the th350 install in the 82 and i need to know exactly what the tranny mount bracket does for the install, its pretty much flat and got four main holes in it, two are threaded and other two are not, instructions tell how to install but not what its for
this is the thm200c kit
thanks for anything
Old Jun 6, 2003 | 02:49 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Isn't it for bolting on the torque arm? I have a TH350 trans also, but with the SSM kit locating/supporting the rearend, I no longer use the torque arm.
Old Jun 6, 2003 | 03:21 PM
ede's Avatar
ede
it bolts to the tran and to the cross member, sort of an adapter
Old Jun 6, 2003 | 05:45 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ede knows which bracket i mean,
i suppose and assume that if my tranny mount bolts up to the tranny and also to the crossmember fine without the bracket then i dont need the bracket ?
thanks!
Old Jun 6, 2003 | 05:48 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i did soem instructions reading and dry fitment of the halves of the torque arm mount and with the B&M brackets, one thing ive noticed is that none of the three flat head machine screws in the B&M kit will attach the first half of the torque arm mount bushings to the large B&M tail arm bracket- the holes in the B&M bracket for this need to be smaller and threaded just like the two screw holes- in the stock silver bracket on the 200c tailhousing bolted to it two long bolts and nuts- are
Im gonna go to NAPA and get a little larger bolts, nuts, and locking washers for these two holes to mount the first half of the torque arm rubber mount
thanks!
Old Jun 8, 2003 | 01:33 PM
ChellysCamaros's Avatar
I would like to know more about this... could you give me an idea what your talking about.. Just did the T5>Th350 swap.. only thing I have left to do is fix the torque arm and the speedo.... Thanks for any help...
Chelly
Old Jun 8, 2003 | 08:56 PM
GarageToys's Avatar
The B&M kit uses a special bracket to attach the torque arm to the TH350 trans. With the SouthSide Machine kit, you get a crossbar that welds to the subframe connectors and two "lift bars" that weld to the rearend housing and bolt to the crossbar to locate the rearend- the torque arm is no longer used.
Old Jun 8, 2003 | 09:28 PM
25thanniversZ's Avatar
use the bracket if you wanna hook up the torque arm
Old Jun 8, 2003 | 10:45 PM
definitive1's Avatar
That B&m bracket kit is kind of a pain. I did the swap about a year ago, and you need to get a part from the GM dealership to complete the install. It says it in the directions you need to get one of two torque arm mounting brackets depending on what torque arm design you have. I didnt bother and just modified the bracket a little. But you would be much better off getting a new crossmember. A few months later I went with the sophn adjustable torque arm with the th350 crossmember, and its a direct bolt in. Best stuff out there.
Old Jun 8, 2003 | 11:57 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
according to instructions the thm200c cars dont need the GM bracket im ready to swap in this engine and tranny very soon, i worked on interior lighting and turn signal wiring today, all is workign good cept for i cant find cigar lighter wire and dont know what the side by side orange and orange/blk stripe wires are at console shifter area, and also two bigger yellow and purple side by side wires with black plug end hanging free up in front driver side corner in front of parking brake pedal and next to main harness there
any ideas ?
thanks
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 11, 2015 05:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
