Missing a spring in the servo?
Old Jul 6, 2003 | 10:04 PM
LeftTurn1LE's Avatar
I was replacing my servo tonight, with the one that comes in the Trans Go HD shift kit. I noticed my original servo is missing the spring that goes behind the plate. Not the cushion spring or the bigger spring inside the piston, but the very last spring. Is this spring necessary? Apparently the stock servo will work just fine without it, considering I never had any problems with my transmission.
Old Jul 7, 2003 | 02:38 AM
Pro Built Automatics's Avatar
Are you talking about the "orange" spring that goes in before the servo? If you are, get one from a local shop. It does help keep the band off.
Old Jul 7, 2003 | 07:30 AM
I don't know if it's orange since I don't have it, but yes it's the one that goes in first before the servo. Is that something I could get seperately at a dealership?
Old Jul 7, 2003 | 02:45 PM
This is the spring I'm talking about. I just ordered one from the dealership for $6.50.
Old Jul 7, 2003 | 03:50 PM
You could pick up one from any local transmission shop for $.050.
Old Jul 7, 2003 | 03:56 PM
Wish I had known that an hour ago. Oh well, too late now I guess. At least I can finally get the 1LE back on the road tomorrow.
Old Jul 8, 2003 | 12:42 PM
I got the spring today. The guy at the counter was a little confused on which spring I needed, and also thought that my car should have came with the 4L60E. I explained to him that I had a 700R4 and was putting in a Corvette servo. Just to make sure, is p/n 8642273 the correct spring? Also, any tips on getting the snap ring back in place? I'm having trouble. It doesn't want to all fit with the extra spring in there. Maybe that's why the last guy left it out.
Old Jul 8, 2003 | 05:11 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
With Transgo kit, discard snap ring, just like the directions that you have there say.
Old Jul 8, 2003 | 06:41 PM
I left out the snap ring that goes in the 2nd piston. I'm having trouble with the one that holds the cover on.
Old Jul 8, 2003 | 07:14 PM
You are supposed to be checking band clearance. When doing this "do not" install the seals. Only install seals on "final" assembly. If the clearance is not correct (too little), you will not be able to get the snap ring in. Do not put in the Trans-Go bronze spacer ring (in the majority of cases it is not needed), unless you have to much clearance. The band must move back and forth the way the "instructions" tell you, "do not" overlook this, it is critical.
Old Jul 9, 2003 | 11:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you do the band wiggle check and can turn the driveshaft in both directions, what would need to be done to discern if there is too much clearance?
RBob.
Old Jul 10, 2003 | 08:26 PM
TwinTurboROC's Avatar
since were on the topic whats the band wiggle test?
Old Jul 11, 2003 | 05:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is a check to see if the 2-4 band will move (wiggle) forward and backward ~ 1/16". If it can not be moved then there is not enough clearance between it and the drum.
RBob.
92firebirdguy
Sep 1, 2016 07:53 AM
86CamaroDan
Sep 29, 2015 10:08 PM
sandman92084
Sep 12, 2015 10:27 PM
scottmoyer
Sep 7, 2015 07:06 PM
FormulasOnly
Sep 6, 2015 10:42 AM
