Tips for DIY Tranny Flush!
Old Aug 15, 2003 | 09:34 PM
25THRSS's Avatar
Well I just got done flushing the tranny myself today. I would like to share my experiences with anyone who would like to know because *** knows I wish I knew what I know now. First thing's first. DO NOT DISCONNECT THE TOP TRANNY LINE! The bottom line is the one you want to disconnect. Lets just say I made a huge mess, lol. Save yourself some troube and just simply loosen the bottom line going to the radiator. Next, get a piece of rubber hose and slide it over the flare fitting and put the other end in a large bucket. Have all your quarts of tranny fluid ready because this stuff comes out REAL QUICK! You want to try to put it in at the same rate the old stuff is coming out. Once the fluid color coming out of the hose changes you can hurry up and turn the car off. If you are changing the filter as well make sure to push it up as far as it will go. The bottom of the o ring will be about 1/4 to 1/2 inch into the hole. Reconnect your tranny lines and bolt your pan back on and you can now refill your tranny with about 5 quarts of dexron III. I chose mobil 1 synthetic and I am very pleased with the results. My vibration and whine in the torque converter are now completely gone and the transmission shifts quickly and better than ever. GOOD LUCK! You just saved yourself around $100+!
Old Aug 16, 2003 | 10:40 AM
25THRSS's Avatar
Guess no one cares
Old Aug 16, 2003 | 11:38 AM
fratsit's Avatar
Car: 1992 Camaro Z28 and '99 Camaro Z28
Engine: 350 TPI Supercharged
Transmission: Pro-Built Street/Strip 700R4
Axle/Gears: Stock
Wrong......
I care. I need to pull my tranny to replace my rear main seal. I am contemplating getting a new trans from Pro-Built, just waiting for him to get back into the shop so we can talk. However, I am gonna try this. Thanks for the insight.
fratsit
honolulu
Old Aug 16, 2003 | 05:33 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
interesting..... but i already changed the fluid and do not want to mess with now. not bad i'll do that one of these days.
Old Aug 16, 2003 | 06:35 PM
25THRSS's Avatar
No problem. If anyone has any questions feel free to ask.
Old Oct 22, 2003 | 04:08 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Ive got a question for you, I want to go over to mobil one, you answerd my post about it earlier. Anyway i'm just curious as to how much fluid I should have around to do this. Do you think it would be cheaper to use that cheap $0.80 a bottle fluid to flush it out, then instead of shutting the car off when it changes color just letting it run dry (or is this really bad for it even though its not moving) the puting in the synthetic, or is it better just to do the flush with the synthetic? Also is there any type of o-ring or sealent on the line going into the radiator that should be replaced?
Thanks, I found this post very helpfull.
Old Oct 22, 2003 | 08:26 PM
25THRSS's Avatar
You will need about 11 quarts to do it, but I would have more on hand just incase you take too much out. There is no o ring or anything on the line. It is self sealing. Glad to know I could help. If you have any more questions don't hesitate to ask. I wouldn't run it dry either. Just keep putting the synthetic in through the fill tube at the top until the fluid changes color. Mine went from dark red to almost pink in color. You must fill it quickly though because it comes out REAL quick.
Old Oct 25, 2003 | 07:57 PM
bigswede's Avatar
Car: 1983 Z28
Engine: stock LG4 305
From a newbie, Thanks for the tip! Now, who makes the best overall tranny filter? And are you running any kind of deep tranny pan? (alum)
Old Oct 26, 2003 | 12:00 AM
25THRSS's Avatar
I just went with an ac delco filter from gm, and no, I am running the stock pan.
Old Oct 26, 2003 | 12:21 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I use NAPA filters, never had a problem with them, apperently there oil filters are pretty good, i'm assuming the tranny ones are the same.
Old Dec 26, 2003 | 01:22 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
when is it that i'm supposed to remove the pan?
Old Dec 26, 2003 | 07:32 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
am I reading this right
you have the pan OFF when your flushing??? I know I must be misreading. also one would think it would push out allot more than you can fill. Did you fill one quart at a time? or did you rig something else up.
Also what sort of vibration did you have before?
And Thanks for taking to time to share
Old Dec 27, 2003 | 11:51 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
You cannot flush with the pan on. You put the pan back on, fill it, then start the car while constanlty filling it untill the fluid comming out is clean. I'm pretty sure thats it...
Old Dec 27, 2003 | 12:35 PM
25THRSS's Avatar
yeap, the pan has to be on. You got it right.
Old Dec 27, 2003 | 12:38 PM
25THRSS's Avatar
Re: am I reading this right
What I did was get all of my bottles of tranny fluid ready by opening them and setting them close to where I could grab them, then I stuck a big funnel in the fill tube, started the car with the lower line disconnected and went to town. You have to pour as fast as you can because you are right, it comes out quick. I stopped a couple times too to help catch up.
Old Dec 27, 2003 | 01:21 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The "average" auto tranny holds about 12 quarts of fluid. Just doing a filter change is about 5 quarts. This method of flushing works pretty well, IF you can keep up. Having everything ready to roll as our fearless leader stated is certainly a good plan.
My suggestion:
1. Flush trans as outlined above.
2. Drop pan, change filter.
3. Refill pan. (5 quarts)
4. Enjoy.......
Admittedly, this will take more fluid, but, it keeps all the fluid clean, and does not circulate dirty fluid through your clean new filter.
NEVER run your transmission without fluid. Good way to burn it up.
An excellent post. Thanks people.
Old Dec 27, 2003 | 02:48 PM
25THRSS's Avatar
next time I do this, I think I might try to restrict the flow by puting some type of valve at the end of the rubber hose, that way the fluid doesn't come out as fast. If you have 2 people it would make things easier as well.
Old Dec 27, 2003 | 04:35 PM
joshwilson3's Avatar
Old Dec 27, 2003 | 05:19 PM
25THRSS's Avatar
I think this would be about as good as a machine without the cost.
Old Dec 28, 2003 | 06:13 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Re: Tips for DIY Tranny Flush!
Great post... after all these years I was beginning to think that I was the only one around who did it this way.
Old Dec 28, 2003 | 06:28 PM
25THRSS's Avatar
I'm thinking maybe a tech article on this?
Old Dec 28, 2003 | 06:47 PM
Old Dec 28, 2003 | 06:51 PM
25THRSS's Avatar
Originally posted by joshwilson3
Do you have a part number or anything for this Valve? What valve would I need to get? Could this be bought at autozone?
i dont have the valve, it was just an idea. Anything would work as long as it would slow down the flow of the exiting fluid.
Old Dec 28, 2003 | 07:01 PM
Old Dec 28, 2003 | 07:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i would skip the valve and just have two people working on the car.....or just use a 2 gallon gas can and pour all the tranny fluid in it and then use a funnel to pour it into the trans....that's what i do when i do it this way....seems pretty easy for me. That way the gas can holds about 9 or so quarts and you already have 5 in the pan....so it should work out pretty well. Gives you an extra 3 quarts to work with.
Old Dec 29, 2003 | 12:30 PM
25THRSS's Avatar
That's a good idea. I might try that next time.
Old Dec 29, 2003 | 07:16 PM
sheachopper
Jul 31, 2019 11:27 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Thaney9
Oct 15, 2015 06:37 AM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
