my car is orignally a 350 tpi 700r4 tranny and i want to put a 4th generatin camaro 6 spd transmission in it do the yfit the block as well as how much hoarspower can these trannies take?
Yeah it will bolt up. About how much it can handle, I heard it can take 450 hp. But I am probaly wrong. Hopefully some one else can conferm that.
so the tranny will fit ok in tehre with the cross memebr mods and what not what ekse am i going to need for this tranny besides the clutch pedal lol
The 94-97 T-56 is rated at 450ftlb from the factory. There are guys out there running 600+hp through them with no modifications but a good clutch.
The T-56 will bolt right up to your L98 motor, I believe you have to do some fabbing for the crossmember, and maybe the shifter but i'm not sure. According to everything I see, its a fairly easy swap. You will need the hydraulic clutch parts, slave cylinder, etc. from the donor car to do it.
Go here http://www.skulte.com/T56.html It will tell you everything you need to know about the swap.
The swap is harder than you think! It was a pain in tha *** cutting the hole in the exact spot on the firewall for the clutch master cylinder and swapping pedals wasn't that fun either but DAMN it's a blast to drive with the six-speed! I used the SPD x-member.
It's a big job but well worth it! I make the shift pattern indicators in both white lettering and yellow lettering if you need one.
ok ow aout the computer my car is orignally an automatic 350 ok and iput the 6 spd in what am i suppose to do for the computer
Get a custom chip. Ya need one for a manual car. Also you can still use the stock puter for SD setups to calibrate the speedo
Kat
Kat
