View Poll Results: which should i use
wait until you swap in a t-56 so you only have to change once..
5.88%
3.23's
23.53%
3.42's
52.94%
3.73's now, why wait, (will they kill gas mileage?)
17.65%
Voters: 17. You may not vote on this poll
which gears do you think?
Old Sep 16, 2003 | 10:13 AM
tj78_'s Avatar
do you guys think i should put in 3.23's or 3.42's, i havea 90 305 tbi RS with 700R4 / 2.73's now.. i need to be able to get good gas milageoo, unless its just a few mpg, i think i will go with 3.23's and i hope to pne day put in a 6 speed, in which case i would still feel a nice jump if i went to 3.73's how much gas mileage difference between 3.42's and 3.23's?
right now, i can jsut spin the tires, well one... after i willg et traction from both so i figure if i go to 3.23's then will it be th esame situation? will teh additional torque froma LSD make it so thta i can just spin them like now? will 3.42s get alot of wheelspin? i wodl rather be hooking up more and not burning my tires, as long as i don't break my tranny mount....
tj
Old Sep 16, 2003 | 10:26 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
what else do you have in this 305? is it bone stock?
Old Sep 16, 2003 | 11:12 AM
tj78_'s Avatar
bone stock with a drop in K & N and a 3" Flowmaster catback...
oh and a little mod i did to get some more air to the filter, jsut gutted a tpi intake and ran it into the front of teh air cleaner...
previous owner was guessing it was between 200-210 max hp
tj
Old Sep 16, 2003 | 12:56 PM
bigals87z28's Avatar
Car: Check The Sig
ahhhh umm... you have a RS 305 TBI but yet some how have a plenum? TPI or TBI DAM IT!! hehehe well, im gunna go on the assumtion that you have TPI and say that 3.73's are deadly for stock or near stock tpi. 3.42's tops.
Old Sep 16, 2003 | 01:40 PM
tj78_'s Avatar
i don't follow as to how you got that i ahve tpi, but im guessingit is how i explained that little mod....
i do have TBI
what i did was takea tpi air duct part of the intake, and gutted it and fit it where it belongs right in the front center near the hatch release and ran the tube strait back as if it was going into the plenum, (i think i ahve my terminology correct) but since i ahve TBI i have a round metal aircleaner... so i got the spout off of another car (a cougar cause i found that it is rivited on and was practically the same diameter aircleaner pan) and cutted a hole/rivited it on to the front of mine as we as leaving the stock tube that runs to teh side and up next to the headlight on...
so i do have TBI
why are 3.73's so deadly for 305 TPI? in what way? gas mileage? how does the fact that i ahve TBI change that?
tj
Old Sep 16, 2003 | 02:06 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Do the math. Find out what you want to spin the motor to (rpms)
Then the circumfrance of you tire.
There are calculators out there that will help. In a TPI/TBI car that's stock, I doubt you'll make enough power in the upper RMPs to use 3.73's.
In other words (manual terms) you would have to shift into an OD gear to keep in your power band.
Old Sep 16, 2003 | 02:46 PM
tj78_'s Avatar
gottcha.... i think im gonna go with 3.23's and if i get a t-56 consider lower.....
tj
Old Sep 16, 2003 | 03:48 PM
nolanr0413's Avatar
Car: Trans am
4.10's or 4.56 , when you get a t56 you should get 4.56 , that new zl1 camaro has 4.56s. My gas mileage sucks with 4.10s but they are great for stop light racing. I ve been getting 7 with my 305 tpi.City driving and flooring it too much . Are you going to get a different rear end that can handle more power?That will affect gears choices .
Old Sep 16, 2003 | 04:49 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
3.73 up is useless. u cant compare a new ZL1 to a TBI injected RS. what kinda reasoning is that? go with the 3.42s thats ur best bet. and 3.73s will kill ur gas mileage and acceleration basically u dont have a use for em.
Old Sep 16, 2003 | 08:49 PM
25THRSS's Avatar
I'll try to actually help here. What plans do you have with the car in the future? What trap speeds do you think you will have?
Old Sep 17, 2003 | 01:03 AM
Car: Check The Sig
3.73's range for power does not go to well with the TPI's short power band. Unless it was modded for better breathing, i wouldnt touch more the 3.42 or 3.45. Even still in your car, since you dont have a heck of a lot of power(that 200hp is a little over the top if you ask me) I say go with maybe a little more to make up for less power. 3.73's would be good, but will eat up the gas a tad more. With teh 6spd, that 3.73 will be reduced to so low it wont matter. With teh 6spd, you could probably get away with 4.10's actualy.
Old Sep 17, 2003 | 07:10 AM
tj78_'s Avatar
im thinking i will jsut get a pair of 3.23's that someone swapped out of a fourth gen.... and put them in myself... i have another rearend at home in worst case, and it woud be a good experience.... this way (3.23) i will feel a good change, def still be in my "powerband" and still have a nice jump possible in the future, and also not kill my mileage.....
thanks,
tj
also, how difficult is it to swap the gears with the rear in the car???
tj
Old Sep 17, 2003 | 07:17 AM
tj78_'s Avatar
yea, the previous owner was claiming it should have around 220 lol.... for some reason i thgouth base was 180 so 200 cold be, but idk withthe base being 170, myself i woudl think 190 sounded reasonable... wish i had a dyno in my garage....
tj
Old Sep 17, 2003 | 10:36 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i went from 3.08s to 3.27 and i felt a big difference just from that small of a swap. the 3.27s are decent but my car needs 3.45s.
Old Sep 17, 2003 | 03:09 PM
tj78_'s Avatar
my plans are a very spirited daily driver, maybe occasional track trip, stoplight fun.... AND i woudl really love to keep up with my friends 85 vette.... (he is all stock with K&N drop ins) and i am all stock other than 3" flowmaster cat back and drop in K &N and the little mod i explained above...
i wan tit so i can spin the tires when i want, but tht its not hard to keep tracktion and really launch/feel the car throw you back and accelerate well,
but the car willl be used for some significant highway milage, i really wod lliek to stay above the 25 mpg like im getting now..... i codl stand a few loss thgouh....
thanks,
tj
Old Sep 20, 2003 | 10:14 PM
laiky's Avatar
no lower than 3.55's i had upgraded from a 3.08 peg leg to a 3.27 9 bolt posi and i felt a nice difference. I wouldn't even bother doing gears. i would just go get a used rear (i prefer 9 bolts) with a posi and whatever lower gears you can find (3.27 or 3.42's) they usually cost around 2-300 bucks and you wont need any special tools. Besides if you get a 9 bolt its a significant upgrade in strength too
Old Sep 20, 2003 | 10:25 PM
25THRSS's Avatar
3.73's would be your best bet. 4.10's would propbably be even better. Considering you have a redline of 5,000 rpm and might even benefit from shifting even higher than that. And anyone who says that the tbi is worthless after 4500 rpm or whatever has no idea what they are talking about. At the track I dropped .5 seconds off of my et by manually shifting at 5,000 rather than letting the car shift itself at 4400 rpm. You most likely wont be trapping more than 85 mph in a stock tbi which would put you right at around 4500 rpm crossing the traps which leave you plenty of room for upgrades. 3.42 would be the least gearing I would put in the car. 3.23 is a worthless upgrade and you wont be getting anywhere near your max performance. With the .7 overdrive gas mileage won't suffer too much. GO WITH ATLEAST 3.73's!
Old Sep 21, 2003 | 01:54 AM
vjo90RS8's Avatar
Car: 2002 Z28
3.73s, look at sig and times with stock heads, cam, intake, and tbi, all on a 160K miles engine and tranny. And i still get about 22-25 miles to the gallon on the freeway driving 250 miles from home to college, but mod ive ever done.
Old Sep 24, 2003 | 07:34 AM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
I'm going with 3.42's. You can find em in almost any of the v6 cars from 82-90. WIth the 700r4, it'll be a nice noticible jump, and shouldn't kill mileage too much.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
