HELP!! TH700R4 Stalling Engine!
Old Nov 19, 2003 | 09:11 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Okay, hope someone has an answer.
I recently bought a car, an 1987 Firebird Trans AM. It has a v-8, 305 TPI. When I bought it, the seller didn't know about it, much as he bought it used also. He did say the tranny was recently rebuilt (less than 1000 miles ago).
Anyways... I noticed, and he also mentioned, that when you're coming to a stop, the RPMs drop really low, and occasionally it stalls. Well I've had the car for about 3 weeks now, and I've done some work on the engine (replaced the intake, due to a broken bolt, with the same exact intake it had on there before), and it started stalling pretty much at every stop. I am pretty sure it is not an engine issue, as it idles perfectly in park and nertral.
I also noticed it helps if slow down to a crawl, and then let off the brakes and reapply them 2-3 times as I come to the final stop, and it seems to kick out of gear, and once again idles fine. It also seems to have no problems when I first put it in gear, and never go fast enough for it to hit second (staying in first before stopping again)
I have tried adjusting the TV Cable, by unlocking it, sliding it all the way back to the firewall, then going to the WOT position, it ratcheted 3-4 notches forward, although it does seem a little better, it still stalls on me.
I also have discovered that this car originally had a Manual tranny, and this 700r4 has been swapped into it, therefore it has no lockup controls. I plan on addressing that very soon... but my main concern right now is the stalling when I stop.
It seems as if it doesn't disengage enough to actually stop, unless I release and re-apply the brakes a few times as I mentioned. I was just wondering if anyone had seen anything like this, and what I should do about it.
I am planning to do a full tune up on the engine, to see if that makes any difference, but I am pretty sure it won't, as it runs fine out of gear, or once the tranny "lets go" at a stop.
I am also getting a gauge to monitor the pressure inside the tranny, so I can accurately set the TV cable. Does anyone know what the pressure should be at idle, and at WOT, in and out of gear?
I appreciate any help anyone can give me, and I would like to thank everyone in advance!
Old Nov 19, 2003 | 09:15 PM
Pro Built Automatics's Avatar
Is there any wiring going to the transmission for the lockup torque converter?
Old Nov 19, 2003 | 09:17 PM
No, there's no wires going to it. Someone else told me that if it's a pre 1987, the Valve Body also has control over lockup, do you know anything about this?
Old Nov 19, 2003 | 09:52 PM
The lockup is electronic controlled (all years). If the valve body was modified with a checkball in the TCC solenoid, it might cause this problem.
Old Nov 19, 2003 | 10:01 PM
Could this problem have anything to do with the Governer or the Servo? Or could my tranny be damaged due to overheating, since it doesn't have any external lockup controls?
I guess I need to pull the pan off, and have a look around in there. What should I look for, other than sticking valves in the valve body and the check ball in the TCC Solenoid?
If there is a checkball in the TCC Solenoid, what would need to be done to fix it? Can I just remove the checkball?
Old Nov 20, 2003 | 04:33 PM
If there is a checkball in there, take it out and see what happens. If this solves the problem, then you can install a vacuum switch to get your lockup back.
Old Nov 20, 2003 | 04:49 PM
Got the pan off it right now, I took the TCC Solenoid out, and applied power to it, it clicked and closed, then when the power is gone, it releases.
Next idea please...
Old Nov 20, 2003 | 09:49 PM
So.. what else should I check?
Old Nov 21, 2003 | 03:25 PM
First, see if this the right year transmission for this vehicle? It could be that the wiring setup is for a 4th gear switch that is normally closed, (most are open). Remove the 4th gear switch (sits next to the 1-2 accumulator, held on with 3 bolts and in the rear corner) and check to see what style it is (normally open or closed) and change to the opposite one. The TCC solenoid, I gather did not have a checkball (look closely) in the snout? Make sure you replace the O-ring on the snout of the solenoid.
Old Nov 21, 2003 | 05:55 PM
The car is an 1987, the Tranny code has a 7 at the front, which makes it a 1987 tranny right? The TCC Solenoid had no check ball, and the o ring looked and felt like brand new (the guy I bought the car from said the tranny was rebuilt less than 1000 miles ago)
My next idea is to check out the governer, think that could be a problem? I am out of ideas on this thing, if anyone can think of anything else I would appreciate them letting me know.
Thanks for all the help Pro Built Automatics! I am beginning to like the sound of a new tranny, but I don't have the money!
Cleotiz
Jan 6, 2018 08:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
