differential gasket
Old Dec 13, 2003 | 12:15 PM
joshwilson3's Avatar
Old Dec 13, 2003 | 03:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I prefer to skip the paper and just use the tubular style rubber one.
Old Dec 14, 2003 | 12:56 AM
Old Dec 14, 2003 | 07:19 AM
ede's Avatar
ede
i prefer the skip the rubber gasket in a tube and use the paper one. i think either would work equally well. if you're wanting a reuable type of gasket you can make one from rubber. try mc master-carr 330-995-5500
Old Dec 14, 2003 | 09:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The RTV does seal better, not that paper doesn't seal adequately though; but RTV is less trouble than making a store run just for a piece of paper. It's really just a matter of laziness.
Old Dec 14, 2003 | 10:13 AM
ede's Avatar
ede
rb, don't know why but i've never quite got on to all this new stuff that's come out for cars in the last 30 or 40 years. i don't prefer RTV for anything over a gasket. and i do know it works as good or even better.
Old Dec 14, 2003 | 12:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
geezer
Like I have any room to talk; I'm so old, I fart dust
Old Dec 14, 2003 | 07:45 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i saw the RTV stuff works better on the diff. gasket then the paper one does. my friend had (just junked the car) 87 gta and he had the gear fluid replaced in his car and ordered the 9 bolt diff gasket for $9 and after a while it started leaking. i replaced my fluid and then had it replaced again once i had my posi installed and well i used the RTV stuff and still sealed tight , no leaks.
Old Dec 14, 2003 | 09:12 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
RTV is fine, actually better then a crappy gasket that will leak without sealer anyway.
Us new school ergh "nEw Skewlers" use Ultra Grey RTV, stronger seal and dries quicker. .
Old Dec 14, 2003 | 09:17 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Designed for high torque applications (predominantly Japanese designs) requiring a unique RTV gasket. Exceeds manufacturers’ performance requirements. Low odor, non-corrosive. Outstanding oil resistance. Guaranteed not to leak. Temperature range -75°F to 625°F intermittent; resists auto and shop fluids and vibration.
Suggested Applications:
Valve covers, oil pans, intake manifold end seals, timing covers, water pumps, thermostat housings.
Old Dec 15, 2003 | 04:46 AM
ede's Avatar
ede
i use ultracopper, don't think there's anything better. i've even used it for head gaskets, instead of head gaskets not with a gasket, on air cooled engines.
Old Dec 15, 2003 | 06:24 AM
bigals87z28's Avatar
Car: Check The Sig
you can order from McMaster? I didnt know you could. I was told at work that only companies could.
Old Dec 15, 2003 | 07:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've seen people told at work to go get the cable stretcher, the left-handed Crescent wrench, etc. etc. etc. Just because somebody said it at work doesn't mean it's true.
Now, if you see it on the Internet though, it has to be true. Right?
www.mcmaster.com
Old Dec 15, 2003 | 07:18 AM
Car: Check The Sig
www.mcmaster.com
Well, considering that we buy from mcmaster over and over and have delt with them longer then you have been alive... I just might take there word over yours? From seeing the order forms for the materials and parts, there is info on thoes sheets that would require you to be ordering for a company. They had some high temp heat shielding. something like 4ft for 10-15 bucks. I was gunna use that to cover my spark plug wires. I was told I couldnt unless it was from the company.
Old Dec 15, 2003 | 07:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Mighty sure of ourselves here aren't we, sonny boy? Did you fight in the Spanish-American War, or what?
So have you actually checked the web site yet and order stuff just like the rest of us, or are you just going to continue to be the young gullible apprentice type?
Old Dec 15, 2003 | 07:33 AM
Car: Check The Sig
Well sorry if I belive my boss that has 2 masters, one in mechanical and one in electrical engineering over you.
Old Dec 15, 2003 | 08:05 AM
ede's Avatar
ede
i've ordered from mc master on more than one occasion and had it shipped to my house. there is a chance they got confused and thought ed ellison was a fortune 500 companey. granger is a bit harder to buy from, i had to tell them it was for big ed's garage and a cash sale.
Old Dec 15, 2003 | 09:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
And you know somehow that I don't?
And this makes what you got told at work correct somehow?
And if they told you the Earth was flat at work, that would make it so too?
Checked the web site yet, young Grasshopper?
"It isi better to be merely thought a fool, than to open your mouth and remove all doubt". There's no doubt any more.
Old Dec 15, 2003 | 09:52 AM
novadude's Avatar
Ditto. Instead of arguing with people who KNOW you can order from them, PLEASE just check the website already!!!
Old Dec 15, 2003 | 10:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think what we need here is some thread sealer. This one seems to be leaking...
Old Dec 15, 2003 | 11:36 AM
Vader's Avatar
Too bad we can't purchase quantities of thread sealant through McMaster, G-Mart, J&L, Johnstone, MSC Supply, Fastenal, Service Supply, or other places that won't seel to anyone but Rockwell and Halliburton.... They must think I'm a division of GM or something.
Gawd, make this go away! My paltry undergraduate degrees simply aren't cutting it in this forum any more, and I feel like a stump.
Old Dec 15, 2003 | 11:37 AM
Guest
Guest
Posts: n/a
Sure seems that way. Might try some red Loctite.
Old Dec 15, 2003 | 11:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not to be blunt.
but where it says company name.
i usually write "Mr Dudes garage" or somthign of that nature.
i actually have a account at Granger under that name.
mod forbid you jsut fill out the form.
Old Dec 15, 2003 | 01:41 PM
Kevin G's Avatar
Old Dec 16, 2003 | 05:01 AM
ede's Avatar
ede
guess big al found out that anyone can order from mc master and now he's questioning what 2 master degrees are good for if the degree holder doesn't know anything, or at least doesn't know everything
sheachopper
Jul 31, 2019 11:27 AM
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
