Pro 5.0 installation
Car: '86 Iroc
Transmission: T-5 with Pro-5.0
Hi guys... Getting ready to put on my Pr0 5.0 and according to the instructions, you need to cut your old shifter boot to go around the bottom of the shifter so nothing can get into it from the top. Is this what you guys did? I had thought about maybe getting another piece of rubber and doing that and then using the stock boot like it was originally used. Comments or opinions please! THANKS!!!
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
I just put one in my father-in-laws 87 Formula, we used the stock boot. Is there something wrong with yours?
Car: '86 Iroc
No, there is nothing wrong with my boot, but my instructions that came with my shifter told me to cut a hole in the boot large enough for the boot to fit over the bottom round part of the shifter and tuck it under the adjustment bolts to keep debris from coming from under the car, getting into the lower boot (if used like intended) and getting into the shifter from the top. (A little confusing, but hope you get what I am trying to say) So, I was wondering if there would be any advantage in trying to get a flat piece of rubber to cut the whole in to seal off the shifter from the outside, then use the original boot like it is. If you don't understand what I am trying to say, I will try to scan the instructions for you. Thanks!!!!!!!!
I think I remember reading that. I will look at the instructions I got and try to expalin what we did later.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I did not have to cut anything to get mine on. It was pretty tight but I squeezed it over and everything bolted up ok and have never had any problems.
That's exactly what we did. No need to replace the boot.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i didn't cut mine either, with a minimal number of swear words, you can get the boot on without cutting anything.
Car: '86 Iroc
Thanks guys!! Maybe I'll finish the swap this weekend. Didn't realize the torque arm bushing was different until last night so now I get to order a poly one.... Always something!!!!!!!!!!!!
Car: 1990 Camaro RS
yes, i rate projects by the swear words used, and the number of beers consumed
Car: '90 RS
Engine: 377 LSX
Car: '82 Z28
Engine: 350HO
Transmission: M4
Iroc8t8
May 4, 2026 08:09 PM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
