Painting a T5?
Old Jan 28, 2004 | 11:44 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Painting a T5?
I was wondering if anyone has painted their tranny, as I was thinking about it while I save up the $ to have it put in (10 degrees and snowy here... I'm not doing it!)
It's pretty corroded and greasy... so what should I do to clean it off and prep it for paint?
What kind of paint might I use... and how many coats?
Thanks!
Old Jan 28, 2004 | 11:52 AM
ede's Avatar
ede
you can use anything you like, results may vary. follow the instructions on the paint. cleaning might not be a bad idea. i'd use rustolium
Old Jan 28, 2004 | 01:04 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I cleaned mine up with castrol super clean then I put scotch bright pads on a buffer wheel and buffed off the oxidaton then I powder coated mine. If painting, do the same, prime then paint.
Old Jan 28, 2004 | 06:03 PM
HeavyBreathinRS's Avatar
Car: 1990 RS
THAT has to be the sweetest thing I've seen like forever....
TRULY AWESOME......:hail: :hail: :hail:
Old Jan 28, 2004 | 06:13 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Sweet.
Did you take out the internals before coating and baking or did you leave it together?
If my tranny looked like that, it'd be put in the living room. Looks like a work of art.
Old Jan 28, 2004 | 07:34 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Looks very nice but you go to all the trouble of powder coating it and then it gets dirty. Black paint is what I use, take the tranny to the car wash blast the crap out of it then paint it to what ever color you want.
Old Jan 28, 2004 | 07:53 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Originally posted by Zepher
Sweet.
Internals out, I was in the process of doing a complete rebuild.
Old Jan 28, 2004 | 08:07 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
novass, I am not paint it person but, that's a very impressive job
Old Jan 30, 2004 | 02:37 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
When I rebuilt my T56 I bead blasted the exterior of all the casing parts and then sealed them with a very high quality clear. If it gets dirty or greasy I just hose it down with soem gunk and water and it shines like new again.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
