clutch install problem
Old Feb 5, 2004 | 06:17 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
this is the first clutch i've ever installed myself. i cant get the disc to stay in the middle bolt on the pressure plate. the motor is still in the car, btw. im doing this on jackstands
Old Feb 5, 2004 | 06:20 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
are you using an alignment tool? The center of the alignment tool goes in the piolet bushing and the outer area goes in the center of the friction plate to keep it lined up while installing the pressure plate.
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
are u using a clutch alignment tool?
Old Feb 5, 2004 | 06:21 PM
woa nova, beat me by a mili second. heh
Old Feb 5, 2004 | 06:22 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
actually a micro second
Old Feb 5, 2004 | 06:27 PM
heh. well it was veerry close.
anyway, i just did my clutch for the very first time, too...
I was also doing my first engine swap, so i had the engine right out. makes it a lil easier....
Meatikis's Avatar
Car: '86 Z-28
oh ok thats how you use it
another question. is the pilot bushing face supposed be flat against the crank(mine sticking out about 1/8" and i can't get it in any farther. i hit it pretty hard and it started to get little nicks on the outside of the bushing. is that gonna be ok?
Old Feb 5, 2004 | 06:28 PM
yea, it sticks out a bit. yours got nicks? you shoulda seen mine, i was wailing on it. heh. so far so good...
Old Feb 5, 2004 | 06:31 PM
Meatikis's Avatar
Car: '86 Z-28
ok im gonna go work on the beast then. ill post results in about 30 mins. hopefully putting the tranny back in will be cake(i gotta go to school tomorrow )
rocn7roc
Sep 21, 2021 02:16 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
Fronzizzle
Aug 17, 2015 02:52 PM
rsrmoore
Aug 7, 2015 08:44 PM
