Built Trans - Shift Slap?
Old Mar 4, 2004 | 09:51 AM
SweetRide45's Avatar
I heard that when you get or rebuild a trans w/, let's say a Trans-Go, Corvette Servs, etc...that when it shifts, it like "clunks" or you can really feel the bang of the shift. Is that true? I know that when it shifts smoothly, they call it wear b/c of slippage. The kit prevents slippage, and in turn, makes it "slap". Let's say it's dealing w/ a 700R4.
Old Mar 4, 2004 | 11:26 AM
Wow, not even 1 view...
Old Mar 4, 2004 | 11:30 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There's a difference between a quick shift and a banging shift... The trans-go kits tend to increase line pressure and make other small modifications to improve the quickness of the shifting... Kits like the B&M shift kits simply remove the accumulator functions and you get a harsh shift...
Old Mar 4, 2004 | 11:46 AM
I see. So, say, getting a 700R4 Street/Strip trans from Pro-Built...that'll shift nice, but won't "jerk" you around?
Old Mar 4, 2004 | 01:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
When the transgo kit is installed properly it will let you feel the shifts with normal driving not harsh just 1/2/3/4. When you floor it with this kit you the shifts become firmer. Its a very good all around driver freindly kit compared to other types. If you wanted a strip only hard shifter then you might consider a B&M but only if you dont really care about the trans life.
Old Mar 4, 2004 | 01:36 PM
Oh, I gotcha. So, it'd be fine to get a Pro-Built trans, and be done w/ it. Sounds good to me
Thanks!
camaro11j
Sep 19, 2018 08:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
