Shifting makes car jump??
Old Mar 10, 2004 | 01:42 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
I have an '87 Camaro LT LG4 with the 700R4 auto tranny. I bought the car used exactly a month ago, and it has had this problem ever since I purchased it. I will hopefully have the time to have it looked at and repaired sometime this week depending on cost, but I would like your opinions first...
After I start the car, as I shift from P into R, D, whatever - the car will jump. It's not too bad when it's warm out, but it still does it enough for you to tell it is NOT supposed to do that. When it's cold or the car has sat overnight, it jumps very badly. The odometer only reads 56xxx, but I'm guessing the car has 156xxx miles on it realistically (if that helps). At first, people were saying it was most likely the mounts, but after I had it looked it the guy said the mounts were okay.
Any clues/tips as to what is realistically causing this? Other then this problem the tranny isn't giving me any other problems. Sounds and shifts just fine. Any help would be very appreciated.
Old Mar 10, 2004 | 02:09 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Sounds like a transmission mount to me. Or possibly the U-joints.
The transmission mount is a really easy fix and the U-joints aren't that bad.
Get underneath the car and look at the tranny crossmember...in the center is the trans mount. Look at it and see if it is broken or loose. If so, replace it. That is probably the problem.
Old Mar 10, 2004 | 09:21 PM
Robbie's87Z's Avatar
Car: 87' Z28 and 96' Avenger
Engine: 355
I, too, have the same problem. Mine's also an 87' LG4 w/700R4. I know it's not my tranny mount, I've already checked that. But, like he said, once it warms up, it doesn't do it. The car shifts hard and jumps when the car is cold. Once it warms up, everything is fine.
Old Mar 10, 2004 | 10:35 PM
EvilCartman's Avatar
Car: '82 Z28
High idle speed maybe?
Old Mar 10, 2004 | 11:06 PM
Engine: 355
no, it's not that... my car idles at about 700RPMs. plus, that wouldn't make the car jump and shift hard from 1st-2nd though.
Old Mar 11, 2004 | 12:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It could be normal, there's an accumulator in the auxiliary valvebody that early 700R4's don't have that softens the shift out of P.
Old Mar 11, 2004 | 08:05 AM
Engine: 355
Ok, that would make sense, but what about the shift from 1st-2nd? My buddy said it maybe that my tranny is just getting tired?
Old Mar 11, 2004 | 11:30 AM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
I stumbled upon this in another thread. According to TKO, they do have an aux. valve body.
Originally posted by TKOPerformance
The 700R4s were significantly upgraded in '87. The earlier units use fewer 3/4 clutches, lack an auxiliary valve body, and are generally weaker than the post '87 counterparts.
Thanks for the input given so far, guys.
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
