15 & 41 tooth Speedo gears
Old Apr 7, 2004 | 08:14 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
here's what you get when you order speedo gears from GM I got the 15 tooth and the 41 tooth for my 3.42 gears Im putting in my 700r4.
They come already put together. cost was about $35
Old Apr 7, 2004 | 08:17 PM
and when you remove the tailshaft from the tranny to do your speedo gears...NOW! would be a great time to replace that crappy *** stock TQ arm bushing.. just from looking at it I cant believe the cheapness of the stock.
Old May 7, 2004 | 12:16 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Where did you get the speedo gears from? Did you go through a chevy dealer?
I work at advance...wonder if I can get them there.
I need a set because I'm going from 2.73s to 3.73s.
Old May 7, 2004 | 05:48 AM
I got them from the dealership.
Old May 8, 2004 | 01:04 AM
Transmission: 4l60e
Is there a part number on the bag? I'm wondering if I can get them from work with my 20% discount.
Old May 8, 2004 | 04:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Nope, Advance or any of the chain stores cannot get these but you can call the dealer on behalf of your store and get them at cost. Hi Mr. Dealer this is 88350 over at advanced I need to see if you stock #XXXXXX. Is that list or my cost ?I'll be right over. Then you get the parts cheaper.
Old May 11, 2004 | 09:59 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sounds like Parts Counter 101.
www.gmpartsdirect.com is another option.
Old May 11, 2004 | 11:02 AM
Transmission: 4l60e
Yeah I emailed gmpartsdirect about some part numbers a few days ago. No reply yet.
I asked them about the speedo gears and about getting a carb fuel tank pickup/sender.
Old May 11, 2004 | 12:31 PM
if you need the teeth count that I got I can give you the part#'s ...they are for 3.42 gears.
THey cost about $35 total...if you can get them at cost like I did. saves you about $20......or so.!
Old May 14, 2004 | 11:10 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
At Transmissioncenter.net you can order them for $17.00 a set.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
roysatikas
Sep 7, 2015 08:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
