anyone ever use/using a powertrax unit?
Old Jun 9, 2004 | 04:21 PM
RiceKiller87's Avatar
Car: '87 IROC
Transmission: 700-R4
i need to put a posi in my car,and im thinkin about using the Powertrax unit. It goes in place of the "spider" gears on the rear end.
Has anyone here used them,is using them,or know some1 who is? how well do they work? are they strong?
thanks for any replys
Old Jun 9, 2004 | 04:24 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Measurements? You don't need measurements when throwing in a new carrier, only when changing the gears. Just get your new posi carrier get the old one out and slip in the new one using the old shims, thats what I and several have done and no problems or whining.
Old Jun 9, 2004 | 04:55 PM
steve8586iroc's Avatar
I don't use one but have heard that they are good. They seem to be fairly simple to install. I believe one of the car mags recently installed one in a camaro. I was thinking chp did it but found the article and it turned out to be an Auburn posi unit. You might also look into the Detroit Truetrac, I believe Randy's Ring & Pinion carries them.
Pasky, where do you see that he mentioned anything about measurements?
Steve
Old Jun 9, 2004 | 05:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ah, the old "edit after someone comments" routine...
I have one in the 8.2" 10-bolt, been there since '01. I used the "Strip/Street" springs instead of the "Street/Strip" springs because the car is street driven primarily to get to the track. The "Street/Strip" are a little quieter and smoother.
I have found a small chip broken off of two corners of the end "dogs". I don't know if a similar problem would exist for a 7-5/8" 10-bolt. Found the first one when changing from 3.08 to 3.73 gears, and the 2nd when changing the gear lube this spring. Didn't seem to hurt anything or affect function of the unit itself.
A hint for improving strength while you're at it: Get a unit for 28-spline axles, and replace your 26-spline axles while you're at it. Also weld the tubes and install a support cover.
Okay, that was a couple-three hints...
Old Jun 9, 2004 | 05:39 PM
Car: '87 IROC
yea,i was pissed earlier and went raging...sad thing is,i knew i was completely wrong after i went back and read it after Pasky said something.
thanks for the help and the hints man. i dont know if im gonna go through and do the axle swap and everything b/c i dont have the money too. several months ago i was going to do all of what u listed and use the PowerTrax unit but did up my daily driver S10 instead.
Old Jun 9, 2004 | 07:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive got a powertrax noslip unit in my bird. Its nothing special but has taken abuse in two different fbodys for a few years. I'd say its worth it although I you probably should decide if you want to gear up now because its a pain to take these things out unless your Five7.
Old Jun 9, 2004 | 08:21 PM
EvilCartman's Avatar
Car: '82 Z28
I used to have one but broke it Worked good for about 8 months though I never sent it in for a replacement since I decided to get a 9 inch rear instead.
Old Jun 9, 2004 | 08:34 PM
five7kid's Avatar
Originally posted by SSC
... its a pain to take these things out unless your Five7.
Good thing they have an 800-number...
Old Jun 9, 2004 | 10:11 PM
Pasky, my bad.
Steve
Old Jun 9, 2004 | 10:40 PM
pasky's Avatar
S'alright .
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
