switching gears from limited slip 3.08 to 3.73 or bigger posi
Old Jun 13, 2004 | 01:21 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i have acess to some rear ends. i would like to swap out my old 3.08 limited slip gears to some 3.73 or 4.11 posi gears. would i have to swap out the whole rear end? i was told i could just swap out the pumpkin. any help?
Old Jun 13, 2004 | 11:10 PM
onebinky's Avatar
With the 10 bolt, the pumpkin isn't removable.
Since you already have a limited slip/3 series carrier, you can swap to the 3.73's or 4.11's without changing the carrier out.
If you do choose to replace the carrier in addition to the gears, make sure you get the right spline count for the axles. Two were available for the thirdgens, I believe 87 was the crossover year.
Old Jun 14, 2004 | 04:57 AM
ede's Avatar
ede
i think you're confused on a point or two. gears have nothing to do with posi or open. all you need to do is install the gears you want. if you want posi then you'd need a posi carrier.
Old Jun 14, 2004 | 09:00 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
You can't use the posi from the 3.08, because its a series 2. The crossover year for 26 to 28 spline axles is 1989. So you probably want a series 3 posi with 28 spline count to go with those 3.73 or 4.11 gears.
Old Jun 14, 2004 | 11:20 AM
ede's Avatar
ede
you can use the series 2 carrier with the correcr gears, in any ratio you want. you don't need to change carreir just because of the series. richmond makes gears that will work for you.
Old Jun 14, 2004 | 12:28 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
ok let me see if i got this right. i can swap out the gears in place of my 3.08, but i cant make it posi?
Old Jun 14, 2004 | 01:17 PM
ede's Avatar
ede
sure you can make it posi, all you need is the correct carrier
Old Jun 14, 2004 | 06:54 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
limited slip=posi
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
