Help with quik t5 question.
Old Jun 29, 2004 | 03:00 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
Just wondering if it 100% necisarry for the little ball and spring to be on the piece that cups the ball on the end of the shifter and the shifter shaft. I hope you know what im talking about cause I forgot to put it in when I was assembling my trans and dont want to have to take the case apart again and re seal it. yea im that lazy.
Old Jun 29, 2004 | 03:21 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I would say yes it is like 99 percent necessary. That ball helps the stick stay locked in. You could probably use it without it but your gears will not click into place and they could fall back out. It is not worth ruining your tranny if you ask me. Don't be lazy and just put it back in.
Old Jun 29, 2004 | 04:05 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yep, you'll have to put it in.
Old Jun 30, 2004 | 02:13 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
damn just what I didnt want to hear. But Ohh well anyone know where to get the little ball or if I can just use a ball bearing for it?? THere was no ball when I pulled it out.
Old Jun 30, 2004 | 02:27 AM
jmd's Avatar
jmd
Get one that fits smoothly and not too sloppy in the offset lever block. If you have the spring still, then you're good to go.
Old Jul 2, 2004 | 06:24 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
can I use a ball bearing???
Old Jul 5, 2004 | 05:17 PM
jmd's Avatar
jmd
reread my last post.
Old Jul 6, 2004 | 10:56 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Get one does not exactally tell me what to get. Can I go to a hardware store and get a ball bearing and throw it in there one that is the right size to fit in the offset lever block?? Or am I going to have to find this exact part again and why wouldnt it have had one in there to begin with, there was nothing but a spring in there>??
Old Jul 6, 2004 | 11:57 AM
jmd's Avatar
jmd
If you got the exact part, then it would fit like I said anyway.
If you went ball bearing shopping, then you would have to find one that fits as I described.
The latter is what I was recommending.
Either someone goofed up when the trans. was previously assembled or you lost it.
The sky is not blue. The light filtered through the atmosphere appears blue.
Old Jul 6, 2004 | 03:41 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Thanks for the help I thought that was what you were trying to say but I wasnt 100% I will probably just go for the latter as you suggested thanks for your time and patience.
Old Jul 6, 2004 | 05:10 PM
jmd's Avatar
jmd
I don't hear that often
zrotten
Jul 4, 2011 04:06 PM
Jeff87IROCZ
Oct 16, 2000 07:49 AM
Jason 85 IrocZ
Oct 11, 2000 11:44 AM
