wierd thump
Old Aug 26, 2004 | 10:43 PM
Daytona T/A's Avatar
Car: 1983 25th Anniversary Daytona 500 Pace Car Trans Am
Engine: 5.0L 305 Crossfire-Injected V8
Transmission: 4 spd. auto
wierd thump
I went to look at this '91 RS for a possible winter car. it's got the 305 114,000 miles. Guy tells me it's got this thump that it does usually when there's at least 2 ppl in the car and you get on it. So we go for a ride- I punch it and he says, "did you feel that?" and I did feel a thump but I wouldn't have noticed- just felt like transmission shifting. He says he had it looked at and the guy told him it was probably some brace that goes bad and does that- says he's replaced a lot of them on "these cars." Any thoughts???
Old Aug 27, 2004 | 01:40 AM
EvilCartman's Avatar
Car: '82 Z28
Transmission mount needs replacing.
Old Aug 27, 2004 | 04:39 AM
ede's Avatar
ede
that's a new one on me
it's pretty common. replace it with a ES poly mount and you'll nevre replace one again
Old Aug 27, 2004 | 12:08 PM
how much to have that fixed???
Old Aug 27, 2004 | 12:35 PM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
I had mine replaced and I don't think it was any more than $20 Canadian or so... its a cheap and easy thing to fix... think it took less than 15 minutes
Old Aug 27, 2004 | 03:01 PM
ok, thanks for the info, guys
Old Aug 29, 2004 | 06:44 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I fixed my Trans. mount for less than $15. Took about an hour, all the bolts were stuck though(took some perswasion, if ya know what I mean). Just backed the car up on ramps, jacked up the transmission alitle(loosen the lower nut first), mine was in two pieces so I just droped the bottom half out and went to work on the top bolts. Solved the thumping problem, might have even increased felt torque, could just be imagining things though.
Max.
Old Sep 3, 2004 | 05:20 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Sounds like the tranny mount bushings on the crossmember might be bad. The X-member will have two parts; the main crossmember and an upper part. There are four bushings in there that absorb the shock of the tranny shifting. The driver's side of mine were non-existant when I bought my 82, and I got them from a dealership for about $40 for the set. Prolly would have been cheaper to have gone aftermarket, but hey, I needed them fast, and there was no more "CLUNK!"
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
db057
Aug 22, 2015 08:17 PM
ShiftyCapone
Car Audio
Mar 1, 2001 12:35 PM
