Bolt in axle housing
Old Aug 27, 2004 | 06:43 PM
hitekstuff's Avatar
Car: 1990 Firebird
Engine: 305 TBI
AHHH! I was trying to change my oil in the rear axle, and the bolt is rounded off, so i went and got an easy out, and it snapped off inside that bolt, any suggestions? I can get a picture if you need to see what i'm talking about, any suggestions welcome!
Old Aug 28, 2004 | 09:16 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
pic would help. so, you are saying the bolt head is still there just rounded? and now it has part of a easy out stuck in it too?
Old Aug 28, 2004 | 11:06 AM
ede's Avatar
ede
what rear end? the fill port is a 3/8 pipe plug wit ha 3/8 female square hole. shouldn't be a bolt. easy outs are waste of time and make more problems than they solve. weld a nut on the stub and back it out with a wrench.
Old Aug 28, 2004 | 12:53 PM
hitekstuff's Avatar
Car: 1990 Firebird
Engine: 305 TBI
This is a pic, you can see i replaced all the bolts i could with new ones, but I couldnt' get that one out, so i couldn't change the oil...
Old Aug 28, 2004 | 03:26 PM
ede's Avatar
ede
ok i understand now, thought you meant a fill plug. try some heat on the casting, or cold ,the bolt should come with a bit of work. if it breaks drill and tap it, or weld a nut on it like i said before.
Old Aug 28, 2004 | 04:16 PM
onebinky's Avatar
who needs a girl when you gotta beautiful car, and cars don't talk back!
Sounds like your car is talking back
I've gotten lucky before by hammering a socket on that's one size smaller. If that doesn't work, really all you can do is what ede is saying. If you have a acetylene torch, then I would definately use that though. Probably the easiest method...
Old Aug 28, 2004 | 06:15 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Hammer a slightly smaller socket on, and once you have a good grip on it, try & tighten it slightly, then loosen it. You'll get it out.
Old Aug 28, 2004 | 11:46 PM
ljnowell's Avatar
That or as said above, weld a nut on there, it'll work most every time.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Gambit TA
Sep 1, 2015 07:27 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
