t-5 swap to turbo 350
Old Sep 4, 2004 | 02:57 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
i am going to swap my t5 and put in a turbo 350 what all parts would what changes.
Old Sep 4, 2004 | 11:16 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Driveshaft, crossmember, driveshaft, speedo gears.
Old Sep 4, 2004 | 11:59 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
i heard something has to change with the torque arm
Old Sep 5, 2004 | 12:18 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you need either a new crossmember like spohn's with the torque arm mount built in, or something like the B&M kit which bolts to the tranny.
Old Sep 5, 2004 | 12:31 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
ya i think i am going to go with spohn's kit another question is what is different between a 5speed console and an automatics
Old Sep 5, 2004 | 08:19 AM
ljnowell's Avatar
I feel compelled to mention it.
You can buy a kit that allows you to use the stock crossmember, torque arm, driveshaft and speedo equipment from your car. It comes with a 700r4 output shaft to install into the th350. Then a spacer block, and you install your tailshaft onto the spacer. You can retain all factory equipment, and have your th350.
http://www.bulkpart.com/Merchant2/me...y_Code=Teckpak
is the link, check it out.
Old Sep 5, 2004 | 05:15 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Would you be selling your t-5 setup? Would you accept a Th-350 as a partial trade? I have one from a truck that I pulled my motor out of sitting here in the garage! I need some extra gearing in mine, and the built th-350 in my car right now just dont have them!
Old Sep 7, 2004 | 09:19 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
the shifter and the shift plate
Old Sep 7, 2004 | 07:57 PM
CrazyHawaiian's Avatar
Car: too many ...
If you can find an early model Camaro/Firebird with the 200R tranny then you can use a lot of those parts for the conversion and save yourself a bunch of problems. You could use the crossmember, the driveshaft, pedals, flexplate, etc. Also dont forget about the cooling part of the swap. Auto's have cooling hardlines that run up to the radiator. You'll probably need those lines as well as a radiator from an auto (with the provisions for the cooling lines). Early model donor/parts car is definately the way to go. 700R4 donor/parts car would work too but be warned that not everything from a 700R4 donor car will bolt up for the TH350 swap. If you do use a 700R4 donor car I recommend you go the kit ljnowell posted (assuming your TH350 is the short tail version).
xkingcodex
Feb 12, 2020 07:43 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
crazynights
Aug 21, 2015 06:53 AM
st.evel07
Aug 13, 2015 06:15 PM
