83 T/A 5-Speed Pedal bushing.
Old Oct 8, 2004 | 07:19 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
I have a problem with a bushing that popped out on my rod assembly that goes to the clutch pedal. Since that bushing came out I don't have any movement and it has thrown the geometry off.
Does anybody know where to pick one of those up at? It is a rubber bushing. This is for a manual clutch for a 83 T/A. It was squeeking real bad then all of the sudden it just slammed to the floor.
Old Oct 8, 2004 | 10:28 PM
Nordbert's Avatar
The bushing should still be available from GM, but you might be able to find something that will work at a hardware store. Maybe
a bushing from a door hinge kit could be modified to fit.
Old Oct 9, 2004 | 08:42 AM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Bushing.
I would have called the dealer but there are none open on Saturday around here. I guess I will check Monday. You do not know what I have went through with this ordeal. I pulled the tranny and clutch assembly thinking the pressure plate or clutch went bad. It turns out this is just 2 or 3 dollar piece of rubber. Just irks me to no end. Thanks.
Old Oct 9, 2004 | 10:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
educate me here, since I've never owned an 82-83 clutch f-body.
The upper rod has a 90 degree bit that slides into a hole in the clutch pedal, yes? And that hole has within it a bushing, into which the rod slips into, yes?
Man, the late A-body stuff was just metal on metal. If that's what you're talking about.
Old Oct 11, 2004 | 01:59 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Yes..and yes
I made custom tubular linkage for mine years ago using spherical rod ends going off an old article in CHP (IIRC).I then welded the hole up in the pedal..and redrilled is so that is was just big enough to let the bolt in the bearing end slip through it.When I did this mod the original bushing was wiped giving me alot of slop.Been working good for the last 6 years.
Old Oct 11, 2004 | 06:44 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Re:bushing
Yeah, the A-body is great and heavy duty. Thank you badz I will have remember your mod if I have trouble after I fix it.
Old Oct 11, 2004 | 07:46 PM
jmd's Avatar
jmd
along with what onebad82z said...
they don't mention anything for third gens on their site, but you could always check with them. http://www.speeddirect.com/ ... a few friends of mine have their rod end linkage in their 78-88 A/G bodies and are totally happy with it.
Old Oct 12, 2004 | 08:04 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
AFAIK no one (6 years ago or now) makes the linkage for the early mechanical linkage third gens.That's why I made my own.I bought all the supplies from Art Morrison Enterprises for less than $45.
Old Oct 13, 2004 | 07:42 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Bushing
I went to the dealer and picked up the bushing and washer. The total was 20.00 for both. I can't beleive that rubber bushing is $16.00.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
2012sergen11
Oct 13, 2015 07:38 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
ironbmt
Sep 27, 2015 06:00 AM
