Look what I picked up on Ebay for 102.50
Old Oct 10, 2004 | 01:32 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
you might not be able to tell, but it's a polished up LS1 DS
Attached Thumbnails Look what I picked up on Ebay for 102.50-driveshaft1.jpg
Old Oct 10, 2004 | 01:33 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
dampner
Attached Thumbnails Look what I picked up on Ebay for 102.50-driveshaft2.jpg
Old Oct 10, 2004 | 02:03 PM
KiLLJ0Y
Guest
Posts: n/a
looks like an ordinary driveshaft thats been polished to me..
i have a drive shaft from an LS1 and mine is a lot beefier than that. are you sure its an LS1?
Old Oct 10, 2004 | 02:17 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Yup, it's 3inch in diameter. And I'm not sure how many ordinary driveshafts came with damners.
Tom
Old Oct 10, 2004 | 02:22 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Tom
More than likely a polished LT1 aluminum driveshaft.
Old Oct 10, 2004 | 02:28 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
What would make you come to that conclusion?
Tom
Old Oct 10, 2004 | 02:59 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The LS1 shafts fail a lot, so I'd be happier if that were the case anyway.
Old Oct 10, 2004 | 03:56 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
What exactly will that driveshaft do for you that your current one wont?
Old Oct 10, 2004 | 03:57 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Consume less power and absorb vibration
Tom
Old Oct 10, 2004 | 04:45 PM
Marc 85Z28's Avatar
The ones that do break are behind very strong engines equipped with M6s, and only at high RPM clutch dumps with a strong aftermarket rear and sticky tires. Other than that...
Old Oct 10, 2004 | 05:04 PM
chris86sc's Avatar
Car: 1986 camaro sc
Transmission: auto
Hey I got one of Those !!
Old Oct 10, 2004 | 05:18 PM
jmd's Avatar
jmd
The LS1 driveshafts are the weakest of all aluminum OEM f-body driveshafts.
Read this https://www.thirdgen.org/techbb2/sho...hreadid=251820
Old Oct 10, 2004 | 09:29 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Look what I picked up on Ebay for 102.50
Not a bad price. How much was the shipping?
Old Oct 11, 2004 | 12:02 AM
Morley's Avatar
Old Oct 11, 2004 | 12:16 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Shipping was only like 25 bucks if I remember correctly. And why does everyone keep insisting that it's an LT1 driveshaft?
Tom
Old Oct 11, 2004 | 12:22 AM
jmd's Avatar
jmd
'cause they own third gens, not fourth, and don't know any better.
here's an honest to goodness fourth gen LT1 M6 driveshaft after failure.
here 1
here 2
here 3
here 4
here 5
Old Oct 11, 2004 | 01:12 AM
Morley's Avatar
Hope they had a D/S loop.
Old Oct 11, 2004 | 01:37 AM
Tom
Well not everyone
LT1 years driveshafts were steel, just like the steel 2.5" 3rd gen ones. GM put in the 1LE Al 2.75" shafts to try to solve customers complaints about vibrations. Then most LS1s got the Al 3" shaft. In anycase, I'd think you'd know if it was a steel 'LT1' shaft or an Al one. Post its dia and that'll settled this discussion real quick.
Old Oct 11, 2004 | 12:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wouldnt steel be a heck of alot heavier? He said it was 3inch diameter and how do you polish steel up like that?
Old Oct 11, 2004 | 02:51 PM
Marc 85Z28's Avatar
That's nice, but I stand behind what I said. I can watch any number of sub 12 second LS1 cars running the stock driveshaft at the track or the street with no problems. I've heard of only a few breaking, and all were what I claimed would break them. Oddly enough, 3 of them were nitroused 6 speeds, spraying off the line with DRs...
Old Oct 11, 2004 | 05:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The stock steel one isn't all that heavy to begin with. I was surprised to see that the aluminum one was just a tad lighter.
My 88 Formula came with an alum. driveshaft which suprised me. Owned it for a year and had no idea till a friend noticed it and told me. I replaced the tranny mount last year and didn't notice the alum shaft.
Old Oct 11, 2004 | 07:50 PM
jmd's Avatar
jmd
I never disputed what you said so you don't need to take it that way. I am just saying that a thirdgen 1LE shaft will hold up better than a 98-02 f-body aluminum shaft.
Old Oct 12, 2004 | 01:49 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
An LS1 driveshaft IS a 1LE driveshaft. Its just updated. In some case's the driveshafts that are in LS1 A4's and LS1 M6's differ. The stronger of the 2 is the Aluminum 1LE driveshaft from an M6 LS1 car. I'm not sure exactly what they are rated with the M6, but if you put one behind and A4, which puts lets stress on the driveshaft in the driveline it should hold up to a significant amount of power. Take a look at the GMMP '02 ZL1 Supercars. A C5 427 block at over 600hp they come with that driveshaft with an M6. Tho at this point one would want to go Chromoly. Especially if your gonna beat on it and launch hard.
Old Oct 12, 2004 | 01:55 AM
jmd's Avatar
jmd
Go back and read what I said. Thirdgen 1LE. They are both aluminum and interchange with each other, but GM changed suppliers for the f-body driveshafts along the line and they are not identical shafts.
No, they don't. They are the same tubing, u-joints, yokes, length and everything. A 1999 f-body aluminum driveshaft is a 1999 f-body aluminum driveshaft.
Go do some wrenching.
thanks
Old Oct 12, 2004 | 02:14 AM
The steel one is 17 lbs and the 1le is 12 lbs. You can polish up steel just like aluminum, just you have to clear coat it right away else it'll rust.
I must have missed where she said it was 3". So its a LS1 shaft.
Old Oct 12, 2004 | 02:22 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
thanks
No the differences in the driveshafts I'm talking about are between the ones that are made of steel vs aluminum used in the LS1 cars, I realise I didnt make my point there clear. GM never put a steel driveshaft in an M6 car from 98-02 is what I was getting at. The F-body driveshafts have been the same length, u-joints, yokes since 82. All that has changes is the tubing material, the diameter and the quality. Anyway.... Either way I have experience with both a 3rd gen 1LE and LS1 3'' Aluminum driveshafts and I believe the LS1 driveshafts to be the better choice. I think a lot agree. Just MHO, no need to bite my head off.
All I was really trying to say was that the LS1 Aluminum driveshaft is not as weak as you make it out to be. I'm not trying to argue with you or anything.
Old Oct 12, 2004 | 04:57 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'm a GUY thanks.
Tom
Old Oct 12, 2004 | 12:48 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
LT1 aluminum driveshaft (which is the same as a third gen 1LE) does not have the dampener, as pictured above, therefore, this is not an LT1 driveshaft.
Old Oct 12, 2004 | 05:29 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
That's what I thought but I didn't wanna take a firm stand on it since I wasn't 100% sure
Tom
Old Oct 14, 2004 | 02:29 AM
I'm a GUY thanks.
Tom
Opps. See what happens when you're not paying attention. I offer my humble apologies to you, dear Sir.
Drone358
Dec 10, 2015 08:16 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
okfoz
Sep 15, 2015 05:22 PM
e3pres
Sep 9, 2015 01:51 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
