trans. knock NOT MOUNT RELATED
Car: 1984 camaro
Engine: 5.0 ho
I've got a 1984 5.0 AT trans. knocks at idle in park. Once you shift into gear (D or R) it knocks unless you have your foot on the brakes.Slight knock below 2500 rpm, gets a little louder until 4000 rpm, above 4000 no noise at all.Also it makes no noise while accelerating, once you let off gas to cruise noise comes back. This is the 5th tranny always the same problem. Any guesses?
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: trans. knock NOT MOUNT RELATED
does it change with engine rpm ?
what i mean is does it knock faster as the rpms climb?
Car: 1984 camaro
Engine: 5.0 ho
I have changed flywheel twice with brand new ones. Also Changed torque converter (stock replacement) also brand new poly trans. mount
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Automatics have flexplates, not flywheels. (sorry, I had to-it bugs me when people use the wrong terms)
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
id guess that the converter bolts are hitting somthing....
and if this has happened to more then one trans, i would be looking at things other then the trans...
if the car isnt moving for the noise, its not the drivetrain... so id be looking at the back of the motor.......
Car: 1984 camaro
Engine: 5.0 ho
First I understand that that in a parts catalog a/ts have flexplates not flywheels. But after sellling auto parts for 5 years people still seem to come day after day calling it a a flywheel.So I feel your pain sorry.Second with the tarns out motor make s no noise while runnig with the flexplate installed bought brand new flexplate bolts for both new flexplates. No clearance issues.With the car on lift noise is clearly coming from trans. Car goes into gear fine shift good, if not a little hard especially going into second.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
perhaps all these trannies have worn front pump bushings. my friends did the same thing. replaced the the front pump bushing and voila knocking noise was gone.
are you using the same torque convertor on all these trannies?
Car: 1984 camaro
Engine: 5.0 ho
[QUOTE]Originally posted by mystikkal_69
[B]perhaps all these trannies have worn front pump bushings. my friends did the same thing. replaced the the front pump bushing and voila knocking noise was gone.
Did his knocking go away with brake pedal depressed before you changed front pump bushing?
Car: 1988 IROC-Z
his knocking went away while in gear, brake applied. while not in gear it did knock @ idle and at higher rpms.
Car: 1984 camaro
Engine: 5.0 ho
