zexel ? what exactly is it and how to install ?
Old Jan 12, 2005 | 08:44 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
thanks
Old Jan 12, 2005 | 09:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They are a 3 series carrier posi out of 10 bolts. They came from 4th gens (excpet the ones that had the Aubrun option and the '98 model year). Any 3 series gear will work with them.
Old Jan 13, 2005 | 08:30 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ah
3.42 is 4 series isnt it ?
* in these 7.5" axles
i forget now
thanks
Old Jan 13, 2005 | 09:26 AM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
no 3.42 is a 3 series gear 4.10 would be a 4 series gear. you can also buy gears of a different series with a 3 series bolt pattern
Old Jan 13, 2005 | 10:14 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok cool deal then, i plan on a zexel for this axle then, sinc eit sounds like it will work, as long as it doesnt require messing with gear settings ?
anyone got zexel install details or URL to such ?
thanks
Old Jan 13, 2005 | 10:17 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You might check to see that you actually have a 3.42 rear in that car... Sounds like a lot has been altered on it already...
Old Jan 13, 2005 | 10:21 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
actually its not very altered cept for GFX pieces and wheels,, its turns out to be a base model camaro with 2.8 and 700, nothing special, the code is GU6 for axle in this car
thanks
Old Jan 13, 2005 | 10:26 AM
ede's Avatar
ede
there is no differance in bolt patterns from one series carrier to the next, reguardless of what you might read on here. there is a differance in the flange thickness on the carrier between carriers and maybe a differance in gear thickness if the gear maker made a gear set to fit a carrier series it wasn't originally offered in.
Old Jan 13, 2005 | 10:34 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yep, i understand,
the difference in series of carriers is the location of mounting flange for ring gear
known that for years, ive disassembled many semi floater rear axles, and full floaters too, car, truck, van, etc.
axles i haev been inside within last ten years so far:
gm 10 bolts, 12 bolts, 7.5/7.625, 8.2", 8.5", 8.875"
dana 44's and 60's
9" fords, 8.8 fords
47-72 eaton/gm corp truck axles,
73-up 14 bolt gm truck 10.5" FF and 9.5" SF
etc.
thanks
Old Jan 13, 2005 | 08:50 PM
rjmcgee's Avatar
Originally posted by Fast68
yep, i understand,
dana 44's and 60's
9" fords, 8.8 fords
etc.
thanks
Damn, sounds like youv'e been in alot of rear ends.
Old May 19, 2006 | 02:41 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
must... not... add... comments...
Old May 19, 2006 | 02:52 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
http://www.torsen.com/ should help a lot
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
