clutch problems
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
clutch problems
i have the cf df clutch and pressure plate installed. but my clutch for rubs a little but on the beeds of the pressure plate. do i need a certain clutch fork, or is mine bent a little bit?
Car: 1988 firebird
Engine: 305 tpi
what do you mean wheres the throw out bearing. yes its on there. do you mean where does it ride at on the clutch fork?
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Aare the weights centered or off to one side? If off to one side re-center.
Also, is throwout bearing on correctly or backwards?
I would verify you have the right parts, and if so then your clutch fork would have to be bent. Is the only thing you changed the clutch (ie flywheel, fork pivot, bellhousing, etc.)?
Is the slave cylinder already hooked up to the fork? If not hook it up and push clutch in once and see if it still hits when released.
theshackle
Aug 31, 2015 10:47 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
