bolting up torque converter
Old Mar 25, 2005 | 01:20 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i just swapped out trannies for the first time, now i have to bolt up tq to the flywheel. the tranny housing is bolted to the engine, and there is a gap between the flywheel and tq of 1/2", am i suppose to move the tq out to the flywheel to bolt it up? i thought it should be all tight against the tq when bolt the tranny to the engine? i have a pic if needed, thanks
Old Mar 25, 2005 | 01:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 1/2"? That seems a little excessive. There should be about a 1/8-1/4" gap when the torque converter is pushed back into the tranny. Are you sure the flexplate is installed correctly? If the flexplate was never changed then the 1/2" gap is normal for your car.
Once everything is correct, you slide the converter to the flexplate and bolt it up. The converter can't be bolted up if it's still pushed into the tranny. It will damage the pump.
Old Mar 25, 2005 | 02:12 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i didnt unbolt the flexplate, so that should be ok, here is a pic
Attached Thumbnails bolting up torque converter-c-documents-settings-yuel.badass
Old Mar 25, 2005 | 03:54 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
I just did mine about a week ago and my converter was a good distance away from the flexplate. I just got a thread or two on all the bolts and slowly went around and tightened them about a 1/2 turn to a turn at a time. Then it pulled the converter out.
Old Mar 25, 2005 | 03:58 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Should cleaned that up a little while it was out
Old Mar 25, 2005 | 04:15 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Atleast where the starter mounts. Don't want any crap acting like a shim wedged in there.
Old Mar 25, 2005 | 06:25 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i will get it cleaned! i wasnt concern about cleaning when trying to put this back together, but now i look at it, it could use a bit of dusting. so it should ok to pull the tq away from the tranny to bolt it up?
Old Mar 25, 2005 | 08:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I already said yes
Old Mar 31, 2005 | 03:46 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: bolting up torque converter
I had the same problem with mine when I put it together. Turns out that I was looking at the TC bolt closest to me at the time (lying on the floor under the car). It had a 1/2 inch gap between the TC and flexplate. But... up at the top, near the top of the bell housing, the TC had little to no gap between the flexplate and TC. I had to lift up slightly on the TC as I brought it forward to bolt it up. This allowed the TC to be centered and to slide into the crankshaft.
My aftermarket TC had an alignment deal on the face that slid into the pilot bushing hole on the crankshaft.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
