9bolt to 10bolt
Old May 1, 2005 | 08:50 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
9bolt to 10bolt
hey i have a 2.77 9bolt with pbr disk brakes. can the pbr's be swapped on a drum or disk 10 bolt? if so what parts do i need?
thx
Old May 2, 2005 | 01:36 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
yeah you need new backing plates a buddy/fellow TGO member just did it heres the thread
https://www.thirdgen.org/techbb2/sho...hreadid=279267
Old May 2, 2005 | 01:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hello i just did this exact swap. 9bolt to a 10bolt from a 87 camaro. everything bolts up. just need to order the caliper mounting plates for a 91-92 camaro. everything else works fine.
i guarentee it.
Old May 2, 2005 | 02:49 AM
3.492rs's Avatar
Car: 89 IROCZ
right on thx. but can i swap my pbr discs onto v6 10bolt drum?
Old May 2, 2005 | 08:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I "assume" the V6 and V8 ten-bolt are the same. The drum flanges will have to be modified. The following links should provide some info about the swap:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
And modding the flanges (to provide a general idea):
https://www.thirdgen.org/newdesign/t...reardisc.shtml
JamesC
By the way, a search is usually a good decision.
Old May 4, 2005 | 02:32 AM
3.492rs's Avatar
Car: 89 IROCZ
thx guys im gonna try to find a disc rear then
Linson
Nov 12, 2015 08:09 PM
N8MAN1068
Nov 14, 2001 10:30 PM
sb406camaro86
Jul 17, 2001 08:29 PM
True Power
Dec 8, 2000 08:17 PM
MikeT 88IROC350
Oct 21, 2000 04:28 PM
