Wont Shift into 3rd when Floored
Old Jul 27, 2005 | 11:23 PM
1990 rs camaro's Avatar
Car: 1990 camaro Rs
Engine: 305 TBI
Hi, I have a 305 TBI w/700r4, i was driving my car about 45mph floored it, and it reached 70 75mph and the tach read 6500 but didnt shift into 3rd, i let up and the car took a second to shift, ive changed fluid and filter, still the same,
Old Jul 29, 2005 | 10:36 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Re adjust your TV/Kickdown cable.
Old Jul 29, 2005 | 11:58 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
yea. them tv cables are a pain in the butt.. There is actually a set of peassure readings that tells you if you have it done exactly... But you need a pressure guage that you can plug into the tranny. I believe it was 700r4.com that had the info, else you could call them up and get it.
Old Jul 30, 2005 | 03:12 PM
Car: 1990 camaro Rs
Engine: 305 TBI
Thanks verry much, ya it does make sence because it dosent make up its mind when shifting,
Old Jul 31, 2005 | 06:44 PM
Car: 86 IROC
If ya need directions on how to set it correctly let me know. There are pressure readings and it's a pretty involved process though not at all tough to do. But it does require a buddy. It's not really all that necessary to do on a basically stock 700.
Old Jul 31, 2005 | 10:16 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Interested, please explain the procedure.
I've relied on trial and error for too long
One of these days I should install a pressure sender in there and log the thing to see what is going on with line pressure during different driving patterns.
Old Jul 31, 2005 | 10:34 PM
JP86SS's Avatar
I just went to 700r4.com.
Very good info on how the system works.
Cleared up many "theories" of how to confirm the setup is "set" properly.
85camarocrazee If you have any additional info, please add.
Thanks guys
Old Jul 31, 2005 | 10:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Good luck. This is a common problem that is rarely caused by a maladjusted TV cable. Most of the time it's worn 3-4 clutches or weak springs.
Old Jul 31, 2005 | 11:11 PM
JP86SS's Avatar
From what I've just read (Very good explainations) my whole problem is definatly the "not returning" to proper start position. "Long spring syndrome" as they called it.
Exactly matches my issues with hard part throttle upshifts and delayed shifts. At least its not a quick damage situation as the alternative short spring is.
At least I'm on the right path now
F-body driver
Mar 6, 2023 11:44 AM
TheTraut88
Sep 11, 2015 05:16 AM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
tonys91rs
Sep 2, 2015 07:07 PM
