Driveshaft Questions
Old Aug 5, 2005 | 05:37 PM
Stevo's Avatar
Car: Pair of 92 Z28s
hi i think my driveshaft has too much play in it or something...
When i have the car is D and hit the gas at prolly 35 let off hit it again let off hit it again and so on i get a little clunk noise like the driveshaft connecting to the rear differential...thats where the noise sounds like its coming from.
Its not that loud of a clunk just enough to annoy you though.
What is drive shaft balancing? Whats the point how do you do it?
And worn out U joints? such a thing? how easy to replace? how expensive?
Im guessing this little clunk came from too many burnouts...even though ive calmed down quite a bit.
Also have a very faint but still there whining sound from the rear at certain speeds...not that loud but i can hear it. Sign of the rear about to go?
Thanks, Steve
Old Aug 5, 2005 | 05:58 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
maybe its your tranny mount. You said that you do alot of burn outs right? That could kill your mount for sure. check it out bro
Old Aug 5, 2005 | 06:38 PM
Stevo's Avatar
replaced that with a poly mount over 5 months ago
I know what it was like without one this is much different and not nearly as bad.
Old Aug 5, 2005 | 06:51 PM
brutalform's Avatar
Possibly excessive backlash in the differential.
Old Aug 5, 2005 | 08:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Driveshaft Questions
Yes there is such a thing and thats what sounds like is wrong.
Old Aug 7, 2005 | 11:18 AM
Stevo's Avatar
Oh and also to add i got under the car i could turn the driveshaft about 1/8 of a turn back and forth with the car in park. Is that play suppose to be there normally?
And and price estimate on how much new U joints would be?
Is it worth yanking some from a car in the junkyard...they dont wear out commonly do they?
Old Aug 7, 2005 | 01:22 PM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
They do wear if you give them to much hammer, i'm surprised at how small the u\j even on my 305 is, it seems tiny for the engine size.
But a decent breakers yard should have one or two that a little old lady has been driving around.
Old Aug 7, 2005 | 03:49 PM
Stevo's Avatar
ive heard there cheap ill check a parts store tommaro before yanking a rusty one out of a boneyard...heh
Irocguy01
Sep 28, 2015 02:03 PM
theshackle
Aug 23, 2015 03:49 PM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
